dizzy wiring
question for all you distributer guys.. i got a 95 civic hatch and i swapped a d16y8 motor into it.. i was wondering how you wiring up the distributer to the harness from the d15b7.. the d16y8 dizzy has only one plug where as my harness has 2 plugs for the dizzy.. any help would be great thanx alot
eric
eric
you don't NEED a conversion harness, you can also just repin the harness using the correct plug. the extra 2 wire plug will not be able to repin, you will have to cut/solder them.
good luck.
good luck.
i have a 95 civic and trying to use a crx distributer can this be done, and the car has spark gettin fuel and air but will not stay running but also has been sitting for ever any help would be cool dont know if the spark is off cause different dizzy or whats going on
thegooddoctorceretti
10
Aug 30, 2007 08:36 AM
intrnsik
Nov 6, 2006 09:10 PM
