Fully built B16 turbo Block
b16 block that is set up for turbo or nitris motor has around 2000 miles on it took it out cause car was hit from behind hard so had to take it out and now parting the set up motor ran fine all motor during the break in didnt want to boost it off the go wanted to make sure it all went together with no leaks just needs some boost have the turbo kit here to put on have the whole motor if intrested in all of it will make you a deal head trans just parting it out block comes with a 12lb flywheel on it the pic is when i first put the block together this block was not no cheap o all done right with the right parts
8.5;1 srp pistons $500
crower I beam rods$700
acl rod bearings$50
acl main berings$50
new main seals $50
front seals $50
water pump $100
oil pump$160
micro polished crank and balanced rotating assembly$200
Machine work $1500
you do the math
Select a picture
acl rod bearings$50
acl main berings$50
new main seals $50
front seals $50
water pump $100
oil pump$160
Machine work $1500
you do the math
Select a picture
