Help w/b16 turbo block
I recently blew a piston due to detonation after putting a turbo kit. I need to RPL my bottom end fast. Not sure if I need everything all together (block w/pistons,rods,crank). Or should I just get my block sleeved? Let me know what you think
Re: Help w/b16 turbo block (navz121)
If you are going to run over 7 pounds of boost, you should sleeve the block. If you are going to replace the crank, rods and pistons ,then you can convert it to a B18 deck height in the process. Detonation will destroy any motor, so even with sleeves the tuning will have to be corrected.
Re: Help w/b16 turbo block (quickcarl)
Sleeve it. JE Pistons, Eagle rods...good bang for your buck set up. Will hold great as long as everything is turned correctly.
Re: Help w/b16 turbo block (murtnabila)
Sleeves are not always nessesary, it just depends on how much power your lookin to make. Or just be gangster and get 2 head gaskets and some arp head studs and crank the boost
96EkTurboHatch
08-26-2002 10:00 PM
