Transmission fluid on B16A2
Old Jun 10, 2007 | 05:04 PM
Techy's Avatar
Default Transmission fluid on B16A2
Where do I put it in at? I need to add some but transmissions aren't my forte. A picture might be nice too. I appreciate any help. Something as simple as this makes me feel liek such a noob.
Old Jun 10, 2007 | 05:29 PM
ekb16's Avatar
u can add it thru the spot on the pic or thru the VSS
http://www.c-speedracing.com/h...d.php
Old Jun 10, 2007 | 06:12 PM
Techy's Avatar
Default Re: (ekb16)
do I have to remove the tranny to fill it? I just need to add some until I can get the leak fixed (bad differential).
Old Jun 10, 2007 | 06:18 PM
Eran's Avatar
HT White Ops
Of course you don't have to remove the tranny. Just fill it up. It takes about 1.9qt's of fluid.
Old Jun 10, 2007 | 06:20 PM
Techy's Avatar
Default Re: (Eran)
oK , it just looks by the pics that it would leak out if I tried to fill it attached. Looks the fill hole is on the side toward the bottom.
Old Jun 10, 2007 | 06:21 PM
Eran's Avatar
HT White Ops
Default Re: (Techy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Techy &raquo;</TD></TR><TR><TD CLASS="quote">oK , it just looks by the pics that it would leak out if I tried to fill it attached. Looks the fill hole is on the side toward the bottom.</TD></TR></TABLE>
Fill from the VSS hole on top.
Old Jun 10, 2007 | 06:23 PM
Techy's Avatar
Default Re: (Eran)
....... OK again, noob with transmissions. Do you have a pic highlighting where that is?
Old Jun 10, 2007 | 06:24 PM
Eran's Avatar
HT White Ops
Default Re: (Techy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Techy &raquo;</TD></TR><TR><TD CLASS="quote">....... OK again, noob with transmissions. Do you have a pic highlighting where that is?</TD></TR></TABLE>
Look on your transmission. There should be two sensors. One screws in like an O2 sensor, and that's your Backup Sensor. The other is your VSS. It should be held in with three 10mm bolts. Remove them, and just pull it out. It should look like a black box.
Old Jun 10, 2007 | 06:25 PM
Techy's Avatar
Default Re: (Eran)
OK cool Thanks!
Old Jun 10, 2007 | 06:30 PM
ekb16's Avatar
the way to tell when ur tranny is filled correctly is to take off the fill plug on the side of the tranny and pour tranny fluid in until it starts to leak out the side fill plug..onces it starts leakin out then just plug and it ur good to go
Old Jun 10, 2007 | 07:15 PM
Techy's Avatar
Default Re: (ekb16)
Can some please post a pic indicating the VSS. I can't determine where it is.
Old Jun 10, 2007 | 07:17 PM
8krdline's Avatar
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">the way to tell when ur tranny is filled correctly is to take off the fill plug on the side of the tranny and pour tranny fluid in until it starts to leak out the side fill plug..onces it starts leakin out then just plug and it ur good to go</TD></TR></TABLE>
Old Jun 10, 2007 | 07:27 PM
Techy's Avatar
Seriously. I can't find the damn VSS. I need a pic. I find the fill hole fine but I can't fill it from there with what I have on hand. I need a pic to help me find the VSS. I'm lookin all over the damn thing and can't seem to find what you are talking about.
Old Jun 10, 2007 | 07:49 PM
ilovemycoupe's Avatar
I'm a Jackass
Default Re: (Techy)
hey bro
http://www.diyimports.com/mtfprint.html
look at this i followed this write up and did it in 30 min's im only 16
have no real mechanical experience and to top it off i did it farely smoothly
just rememberto unbolt the filler hole first...this is a must because say you cant unbolt the top filler hole and you drain it first your screwed and have no way to refill tranny fluid...
also make sure you fill threw top drain hole until it starts coming outt the filler hole THEN YOU STOP....AND WALA YOUR DONE...
p.s.if it's not too much to ask check the sig
Old Jun 10, 2007 | 07:54 PM
boomersz's Avatar
Default Re: Transmission fluid on B16A2 (Techy)
i always do mine through the vss
Old Jun 10, 2007 | 07:55 PM
Techy's Avatar
OK, I'm tryin to do it through the damn VSS. I need a picture cause I have no ****** clue where the VSS is or what it looks like.
Old Jun 10, 2007 | 07:56 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: Transmission fluid on B16A2 (DrZoidberg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrZoidberg &raquo;</TD></TR><TR><TD CLASS="quote">i always do mine through the vss</TD></TR></TABLE>
I just get a funnel and some heater hose and I don't have to mess with the vss at all.
Old Jun 10, 2007 | 08:00 PM
I'm a Jackass
Default Re: (Techy)
https://honda-tech.com/zerothread?id=1082359
not a very good pic but hope it helps
Old Jun 10, 2007 | 08:02 PM
boomersz's Avatar
Default Re: Transmission fluid on B16A2 (ek forever guy)
Old Jun 10, 2007 | 08:12 PM
Techy's Avatar
THANK YOU!!!! God, I was jsut about to post a pic of one off my D16Z6 to determine if that was a VSS or not and it is. (I just so happen to have a D16Z6 sitting in the floor 6 feet away from the EK.
Old Jun 10, 2007 | 08:13 PM
boomersz's Avatar
Default Re: (Techy)
yeap.
Old Jun 10, 2007 | 08:19 PM
Techy's Avatar
Thanks again for the pics. I'm callin it quits for the night cause I'm accident prone and everyone's in bed. I'll grab a friend to help in a day or 2.
JDMfrontedLS
17
Jun 23, 2006 11:08 AM
sleepermachanic 8
May 16, 2006 07:04 PM
srv3fender
Jun 15, 2004 08:04 AM
TommyV
Honda S2000
Apr 14, 2004 08:53 AM
kotetu
Jun 1, 2003 07:00 PM
