Transmission fluid on B16A2
Where do I put it in at? I need to add some but transmissions aren't my forte. A picture might be nice too. I appreciate any help. Something as simple as this makes me feel liek such a noob.
Re: (Eran)
oK , it just looks by the pics that it would leak out if I tried to fill it attached. Looks the fill hole is on the side toward the bottom.
HT White Ops
Re: (Techy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Techy »</TD></TR><TR><TD CLASS="quote">oK , it just looks by the pics that it would leak out if I tried to fill it attached. Looks the fill hole is on the side toward the bottom.</TD></TR></TABLE>
Fill from the VSS hole on top.
HT White Ops
Re: (Techy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Techy »</TD></TR><TR><TD CLASS="quote">....... OK again, noob with transmissions. Do you have a pic highlighting where that is?</TD></TR></TABLE>
Look on your transmission. There should be two sensors. One screws in like an O2 sensor, and that's your Backup Sensor. The other is your VSS. It should be held in with three 10mm bolts. Remove them, and just pull it out. It should look like a black box.
the way to tell when ur tranny is filled correctly is to take off the fill plug on the side of the tranny and pour tranny fluid in until it starts to leak out the side fill plug..onces it starts leakin out then just plug and it ur good to go
Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 »</TD></TR><TR><TD CLASS="quote">the way to tell when ur tranny is filled correctly is to take off the fill plug on the side of the tranny and pour tranny fluid in until it starts to leak out the side fill plug..onces it starts leakin out then just plug and it ur good to go</TD></TR></TABLE>
Seriously. I can't find the damn VSS. I need a pic. I find the fill hole fine but I can't fill it from there with what I have on hand. I need a pic to help me find the VSS. I'm lookin all over the damn thing and can't seem to find what you are talking about.
Re: (Techy)
hey bro
http://www.diyimports.com/mtfprint.html
look at this i followed this write up and did it in 30 min's im only 16
have no real mechanical experience and to top it off i did it farely smoothly
just rememberto unbolt the filler hole first...this is a must because say you cant unbolt the top filler hole and you drain it first your screwed and have no way to refill tranny fluid...
also make sure you fill threw top drain hole until it starts coming outt the filler hole THEN YOU STOP....AND WALA YOUR DONE...
p.s.if it's not too much to ask check the sig
Ek Forever y0!
Re: Transmission fluid on B16A2 (DrZoidberg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrZoidberg »</TD></TR><TR><TD CLASS="quote">i always do mine through the vss</TD></TR></TABLE>
I just get a funnel and some heater hose and I don't have to mess with the vss at all.
THANK YOU!!!! God, I was jsut about to post a pic of one off my D16Z6 to determine if that was a VSS or not and it is. (I just so happen to have a D16Z6 sitting in the floor 6 feet away from the EK.
Thanks again for the pics. I'm callin it quits for the night cause I'm accident prone and everyone's in bed. I'll grab a friend to help in a day or 2.
JDMfrontedLS
17
06-23-2006 11:08 AM
sleepermachanic 8
05-16-2006 07:04 PM
srv3fender
06-15-2004 08:04 AM
