no spark
Old Jun 10, 2007 | 03:51 PM
93baggedcivic's Avatar
Default no spark
hey guys i just got done rebuilding my motor (d15b7)rings bearings gaskets i pulled the head didnt remove the dizzy.i connected all my wires and im getting gas you can smell the gas.i sprayed gas into the intake and it still wouldnt fire so i pulled a spark plug and put it on the plug wire and put it next to a ground and it didnt spark.i checked all my wires everything is plugs in and my grounds are all hooked up to.what else could it be?
Old Jun 10, 2007 | 04:39 PM
Mr.EM1_EK's Avatar
Default Re: no spark (93baggedcivic)
your dizzy is probably bad. i just changed one for a friend he had the same problem.
Old Jun 10, 2007 | 04:44 PM
energ3tic2's Avatar
you didnt take off the dist.? take it off and make sure the rotor is not 180 off
Old Jun 10, 2007 | 06:42 PM
the thing is before i rebuilt the motor is it would start every once and a while like a ground was loose and it would make a contact and then it would start and run fine
ProjectEvilEj2
Jan 1, 2009 08:10 AM
Civic Hybrid
10
Aug 17, 2008 09:35 AM
2000h22a
Aug 4, 2008 12:48 PM
95turbohatch
24
Apr 7, 2004 08:07 PM
MikeTV
Feb 14, 2004 10:17 PM
