Loosing oil fast. PLEASE HELP
Old Jun 10, 2007 | 02:25 PM
B18C5_VTEC's Avatar
Default Loosing oil fast. PLEASE HELP
Hello. i have a 96 honda civic with a 98 b18c5 engine swap. i am having to constently put more oil in my engine. It dosnt seem to be burning it up but there are somtimes clouds of smoke. when i change the oil it is very black. i have comprestion tested it and it is in a good compretion. i have replaced the valves so it cant be them. please help. thanks
Old Jun 10, 2007 | 04:55 PM
20ls01's Avatar
rebuild time piston rings
Old Jun 11, 2007 | 03:32 PM
mugenracer's Avatar
Default Re: (20ls01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20ls01 &raquo;</TD></TR><TR><TD CLASS="quote">rebuild time piston rings</TD></TR></TABLE>
I had same problem on my last car, oil rings were shot.
Old Jun 11, 2007 | 05:19 PM
92TypeR's Avatar
FSAE
Default Re: Loosing oil fast. PLEASE HELP (B18C5_VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5_VTEC &raquo;</TD></TR><TR><TD CLASS="quote">i have comprestion tested it and it is in a good compretion. i have replaced the valves so it cant be them. please help. thanks</TD></TR></TABLE>
Oil rings and compression rings are two different items. You can have perfect compression but sh*tty oil rings.
This is a common occurance on DOHC VTEC B-series motors. If you don't break in the engine properly (read), your oil rings will suffer the consequence.
Old Jun 11, 2007 | 05:42 PM
h8ted ek's Avatar
Default Re: Loosing oil fast. PLEASE HELP (92TypeR)
im having the same problem. pretty decent compression acrosss the board at
cylinder 1-4= 220-225-235-230
good luck, im hoping to just hone the cylinder walls then widen the cylinder wanting to keep it like stock.
Old Jun 11, 2007 | 07:36 PM
B18C5_VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">
This is a common occurance on DOHC VTEC B-series motors. If you don't break in the engine properly (read), your oil rings will suffer the consequence.</TD></TR></TABLE>
Thanks for the link. Do u still have to break in a motor that was used and already had about 40 k miles on it. cus that is how many miles r on this motor when i bought it. also when we built the motor all we added was cams and valves ect. we never touched the bottem end. and we broke the cams in at 2,500 rpms for 30 mins. thanks
x_doug-x
11
Apr 1, 2008 10:56 PM
itrdave
May 1, 2007 10:44 AM
JDM B16A
Jul 25, 2006 07:57 PM
kihun_cha
Jan 2, 2006 07:45 AM
civic-si-2000
18
Sep 10, 2004 09:15 AM
