problem with the 5spd transmission on 96 acd Ex trim
Old Jun 10, 2007 | 12:28 PM
howard-zhang's Avatar
Default problem with the 5spd transmission on 96 acd Ex trim
i have a hard time to shift from 3rd gear to 2nd gear, may i know how to fix it? it's 96 accord ex 5speed manual transmission. Thanks
Old Jun 10, 2007 | 04:55 PM
Schmitey's Avatar
Default Re: problem with the 5spd transmission on 96 acd Ex trim (howard-zhang)
What's the situation? Downshifting into what would be high RPM's? Is there a grinding sound or anything?
Gut instinct is to say synchro's are shot if everything else shifts fine.
Old Jun 10, 2007 | 07:59 PM
Default Re: problem with the 5spd transmission on 96 acd Ex trim (Schmitey)
It's hard to get into the 2nd gear from higher one when i try to turn the corner, and it is hard to get into 1st gear at starting. there were some grinding sounds coming out also.
Old Jun 11, 2007 | 05:21 AM
hondadude's Avatar
Be sure you have Honda MTF or 10w30 oil in the trans.
Many times I've seen the trans full of gear oil, and that causes problems.
Old Jun 11, 2007 | 06:30 AM
Default Re: problem with the 5spd transmission on 96 acd Ex trim (hondadude)
how can i check whether the transmission oil good or not?
Old Jun 11, 2007 | 07:05 AM
mikex1337's Avatar
You can usually tell by looking at the dipstick. But I think the above guy was referring to the brand of the oil. Make sure you are using Honda MTF.
Old Jun 11, 2007 | 05:18 PM
Schmitey's Avatar
Default Re: problem with the 5spd transmission on 96 acd Ex trim (mikex1337)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikex1337 &raquo;</TD></TR><TR><TD CLASS="quote">You can usually tell by looking at the dipstick. But I think the above guy was referring to the brand of the oil. Make sure you are using Honda MTF.</TD></TR></TABLE>
You clearly don't have a damn freaking clue what you're talking about!!! When was the last time you saw a 5spd auto on a 96 accord? And yes, you do put regular oil in a Honda manual tranny...I've even asked Honda techs.
Manual tranny's have 2 drain/fill plugs. One above the other. The lower is the drain obviously and the upper is the fill. Using a tube on a funnel that is inserted into the upper hole, fill it up till fluid starts to spill out.
Personally though, I'm thinking you may have either a bent fork or a leak in your hydraulic clutch system. It sounds like its not fully disengaging if you're grinding gears. Anyone else think this is a possibility?
Old Jun 13, 2007 | 08:35 PM
good point
Old Jun 13, 2007 | 11:39 PM
SearchBeforeUPost!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schmitey &raquo;</TD></TR><TR><TD CLASS="quote">
Personally though, I'm thinking you may have either a bent fork or a leak in your hydraulic clutch system. It sounds like its not fully disengaging if you're grinding gears. Anyone else think this is a possibility?</TD></TR></TABLE>
or the synchros going out?
xxnuttybarxx
Aug 21, 2007 06:05 PM
elmo2006
Honda Civic (2006 - 2015)
Nov 3, 2006 01:48 PM
White_EK49
Nov 4, 2005 09:39 AM
ShadowJester
Sep 26, 2005 05:23 AM
2fcknfst
Oct 4, 2003 03:35 PM
