gear
Old Nov 3, 2005 | 08:39 PM
White_EK49's Avatar
Default gear
it pops out of 4th gear while driving. all the other gear is fine, wtf..... anyone has encounter this experience or what I need to buy to fix this issue. tried posting on tech. no luck..
Old Nov 3, 2005 | 11:41 PM
xxxmikenicexxx's Avatar
Default Re: gear (slow29)
I know in fifth gear it can pop out due to low transmission fluid...fourth could also do the same...give it a check just to be sure. If it is not low then it is definitely an internal problem which would require pulling it and repair, I hope that is not your case. If it is low, you should drain and refill with Honda MTF to be safe. Good luck!
Old Nov 4, 2005 | 09:39 AM
White_EK49's Avatar
Default Re: gear (xxxmikenicexxx)
no it's an internal definitely. change the oil twice. no metal shaving came out. must be a bent shift fork.
dr.vroom
Transmission & Drivetrain
11
Apr 30, 2014 11:31 AM
PsychoSiRex
Honda Civic (2006 - 2015)
Sep 16, 2009 09:15 PM
ekcoupe88
16
Apr 26, 2007 09:05 AM
bustedasscivic
Nov 16, 2003 09:59 AM
b20civic
Sep 8, 2002 11:33 PM
