f23
Old Jun 10, 2007 | 11:49 AM
power11's Avatar
Default f23
F23 motor any good. explain this motor
Old Jun 10, 2007 | 12:59 PM
accordselux's Avatar
Me Gusta History
Default Re: f23 (power11)
It's a decent motor, but put any real power through it on a turbo and it won't last as well as an F22 would. Plus F22 has a bigger aftermarket following.
Old Jun 10, 2007 | 01:01 PM
wzachmorris's Avatar
Default Re: f23 (accordselux)
i wish accord selux would explain why because its got iron sleeves which is good for turbos
Old Jun 10, 2007 | 06:01 PM
jabontke's Avatar
Default Re: f23 (wzachmorris)
What kind of sleeves are in the F22? And fi you are going to build a motor for boost, why choose an F23 when you can add iron sleeves to an F22?
Old Jun 10, 2007 | 06:24 PM
stinker504's Avatar
The F23 is a great motor if you plan on building it for boost.
T3/To4e 63 AR at 17-18 psi my motor made 364ph 350ftlb.
Old Jun 10, 2007 | 06:47 PM
Me Gusta History
They can't handle as much boost as the F22. I believe the reason was they switched to a different piston ring and the design was weaker on the 23 vs 22.
You can put a decent amount of power (250hp, maybe 7-8 psi) through a 23, but not as much as you could with a 22.
slammed_94s10
Sep 13, 2009 06:00 PM
Teddieb15
Dec 4, 2008 09:40 AM
whatisJDM
Apr 14, 2007 12:49 PM
Slick GS-R
Mar 22, 2002 04:12 PM
