H22A4 Normal compression rating ?
I can't find a normal compression rating for my engine. It's an H22A4, with 119,000km on it. I bought a compression tester and got these results:
Cylinders:
1: 212psi
2: 210psi
3: 211psi
4: 210psi
I know they are in good range of each other, but is that compression good? What's normal, 200psi, 175psi, 250psi?
help
Cylinders:
1: 212psi
2: 210psi
3: 211psi
4: 210psi
help
those numbers are completely,entirely,unimaginably,stupefyingly,reta rdidly horribl
-y Wrong in any which way!!!!!! wtf did you do to the poor thing???
jk, those numbers are money
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz »</TD></TR><TR><TD CLASS="quote">those numbers are completely,entirely,unimaginably,stupefyingly,reta rdidly horribl
jk, those numbers are money</TD></TR></TABLE>
lmao
lmao
Haha
Great, I'll redo the test with WOT. But when should I worry about carbon buildup? I heard that if the numbers are realy high it means there's corbon build up.
Haha
