Water Temp. gauge
i just bought a Speed Glo water temp. gauge for my 94 accord ex. The only wire that looks like might be hard to connect is the sender wire. I just want to know if anybody knows where to connect the sender wire??
[Modified by gatoracer, 7:25 PM 6/4/2002]
did your gauge come with a sender unit or just a wire??
i tapped my sender unit into the upper rad hose housing that bolts to the head. I've seen a couple different ways....u could also, remove your old coolant temp sender and tap it in there but it will disable your stock gauge unless u make some sort of T-fitting.
[Modified by Tripz, 5:50 AM 6/5/2002]
VTECR021
Apr 22, 2004 08:04 PM
