Mph speedometer doesnt work but rpm does..
Hey guys,
I used to drive a Integra LS but I traded it with my friend for a Del Sol B18.. which is okay since it didn't get a ECU change still running off D16.. but the problem is that the RPM is working but my MPH is dead..i would think its wiring problem.. or the speed sensor is bad.. but it seem odd because the rpm is surely running... could it be the speedometer itself is bad and just need a different one?.. it been like that ever since it got swapped to b18
someone correct me if im wrong but its prolly speed sensor if not that maybe a certain wire on the loom going specifcly to the gauge cluster (highly unlikely) its either one or two seperate plugs should be easy to check out. and if not that maybe the cluster was droped and a circuit in theyre is fucked up?. check the speed sensor first.
i think the sensor is new when he swap the tranny in... i think its the cluster because the guy that swap the motor did bad on wiring..
RPM does work... ii'm getting a speedometer tonight.. if it work then it must be it.... thats why i dont like it when someone swap my motor.. i rather do it myself.... hahha :-)..
im pretty sure if it was the vss you would be throwing a cel, does the spedo work at all? try swapping clusters to see if this solves the issue.
planing on doing that tonight.. it must be the cluster because the lights on it doesnt work and the gas meter is wrong... because it was 1 quarter away from empty and it died on me.. but i will check the speedo sensor.. thanks guys
