Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
need help changing timing belt marker info?
Old Jun 9, 2007 | 07:58 PM
toniandfredo's Avatar
Default need help changing timing belt marker info?
I'm triying to change my timing belt but can't get the timing right does anyone know what marker on the belt it should be set to?
Old Jun 10, 2007 | 07:45 AM
s13_240sx_92's Avatar
Default Re: need help changing timing belt marker info? (toniandfredo)
There is no marker on the belt, only on the pullys
Old Jun 10, 2007 | 11:58 AM
2004es2's Avatar
Make sure the cam gear and the crank pulley are at tdc. Then if you dont have the proper tools its gonna be a bitch to take off the crank pulley to get to the belt tensoner so my advise is if you dont have a good impact wrench then you should have a shop do it for you.
Old Jun 10, 2007 | 02:47 PM
Boilermaker1's Avatar
DO NOT impact gun the pulley. You really dont want to shock load the crank like that.
Get the pulley tool, a 19mm 1/2" drive socket, an 18" socket handle and slip a 5 foot pipe over it. Lever the tool and the socket its attached to under the axle, take the bumper off so you dont scratch it, and just lever it off. Its not too bad with enough leverage. As far as the marks, the cam pulley points UP, as indicated on the gear, then line up the mark on the crank pulley with the line on the timing cover.
Old Jun 10, 2007 | 04:48 PM
2004es2's Avatar
Yeah i baught the tool for mine but if you don't have a choice or cant ge the tool in time the impact is a last resort.
Old Jun 10, 2007 | 06:28 PM
Default Re: (Boilermaker1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 &raquo;</TD></TR><TR><TD CLASS="quote">DO NOT impact gun the pulley. You really dont want to shock load the crank like that.
Get the pulley tool, a 19mm 1/2" drive socket, an 18" socket handle and slip a 5 foot pipe over it. Lever the tool and the socket its attached to under the axle, take the bumper off so you dont scratch it, and just lever it off. Its not too bad with enough leverage. As far as the marks, the cam pulley points UP, as indicated on the gear, then line up the mark on the crank pulley with the line on the timing cover.</TD></TR></TABLE>
I've seen the dealer by me use an impact, I think they will always do it that way just because it saves time. Not that its right.
Anyway just to add what you said you will want to use an impact socket and extension if needed. Ordinary chrome sockets tend to break with that kind of force.
1320london
Jul 29, 2017 02:55 AM
Powered by VTEC
Jan 29, 2008 05:58 PM
HBK
Sep 1, 2005 09:37 AM
Mr. Softee
Oct 11, 2003 11:35 PM
Jonathan_ED3
Apr 12, 2003 02:55 PM
