problem with my tail lights/seat belt light
Old Jun 9, 2007 | 05:37 PM
freshly boosted DOHC ZC's Avatar
Default problem with my tail lights/seat belt light
welp about 2 weeks ago i had to get my car towed home due to my oil line cracking on me from the turbo to the oil sender unit. i had my dad come and tow me home cause i was only about 2.5 miles from home so we towed it home with your normal chain hooked to the tow hook. as we were on our way back up a hill my pops accidentally jerked the car really hard. about a week later i got my parts and got the car running again and noticed that my break lights no longer work and my seat belt warning light keeps blinking in the center of the dash. bulbs on the lights are good and the parking lights also work. is there not a fuse for just the break lights? any ideas what could be wrong? all advice/ help is greatly appreciated. cars a 89 crx si.
Old Jun 10, 2007 | 01:35 PM
Default Re: problem with my tail lights/seat belt light (freshly boosted DOHC ZC)
friendly bump would like to figure this problem out whlie i start to do a little rebuild on my engine
Old Jun 10, 2007 | 01:58 PM
91BlueEF9's Avatar
Well, im not all to sure what the problem might be, but i mean, if he jerked the car that badly, maybe a plug came loose behind the cluster, which could be why your seat belt light is flickering, i know when something is unplugged around the cluster, none of my lights come one, so it's just something you could check. also look under your dash at all the fuses, and maybe the ones under the hood. sorry i dont exactly know...i did just talk to one of my buddies and he said to check all your fuses and your grounds, so its just something to check. sorry i cant be more help.
Old Jun 10, 2007 | 02:26 PM
95gainfla's Avatar
my damn seatbelt light wont go off either even with both belts plugged in.
and my door light also.
i hate when lights are on that shouldnt be*bangs head*
Old Jun 18, 2007 | 08:52 PM
carlthecrx's Avatar
Default Re: (95gainfla)
there is a fuse for the break lights in the fuse box under the hood.. i THINK it's the second one from the passanger side.. at least on mine.. not sure about the seat belt light though.. mine has never worked since i've had the car
Old Jun 18, 2007 | 11:53 PM
charlee's Avatar
Default Re: (carlthecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carlthecrx &raquo;</TD></TR><TR><TD CLASS="quote">there is a fuse for the break lights in the fuse box under the hood.. i THINK it's the second one from the passanger side.. at least on mine.. not sure about the seat belt light though.. mine has never worked since i've had the car </TD></TR></TABLE>
agreed. i just had that problem like 5 min ago at work. those problems expletive with your mind lol. i was in alldata for a while lol
Old Jun 19, 2007 | 08:50 AM
doublethink's Avatar
do you have a helms?
theres a control unit for those seatbelt locking mechanism AND that little indicator light above the rear view mirror.
it also has a troubleshooting flowchart, i suspect that unit may have been damaged internally from the shock you gave the car while towing it...
or it could be a short somewhere, based on what your saying about the lights. either way you have some wiring tracing to do if all the fuses are good.
Old Jun 19, 2007 | 09:45 AM
jdmrex90si's Avatar
my friend had the same problem hit a big bump one day and his breaklights and gauge cluster lights stoped working so he changed the fuse under the dash in slot 8 taillights itnstument lights, and they worked again
Old Dec 28, 2008 | 02:27 AM
OAKHILL510's Avatar
mang my seat belt light keep blinking after 5mph...it started to do this after i installed a 88-89 cluster into my 90 civic hb...so when i put the old cluster everything is koo like when i bucket my belt the light goes off but after 5 mph keep start to blink from the cluster and the thing on the rear view mirror...wtf......also my door light use to go off after i close the door but now it just stay on all the time
Old Dec 28, 2008 | 02:28 AM
OAKHILL510's Avatar
p.s the 88-89 cluster wasnt for that year so i put in a 90 cluster and it does that blinking to that one too
Old Dec 28, 2008 | 05:27 AM
Je2RiT's Avatar
All grounds tight?
Old Dec 28, 2008 | 07:49 AM
JDMgunmetalCRX's Avatar
Originally Posted by Je2RiT
All grounds tight?
lol you have my quote as your siggy
cholo whip...
spens 91 Ef
Jun 10, 2009 05:45 PM
ESP-net
11
Dec 29, 2006 09:46 PM
slammeddelsol95
Dec 30, 2004 07:46 AM
