check engine light
my speedo has quite working along with my vtec check codes and am only gettin a vss code number 17 why would my speedo not allow my vtec to work is it a totally separate problem im not seeing any help would be great
Check the connection on the VSS. If it is not the connection, then replace the VSS, and it should fix all your problems.
If the car loses it's speed reference, VTEC will not engage. Check out this thread:
https://honda-tech.com/zerothread?id=830163
Eg_hatch_95
Mar 15, 2009 10:35 PM
springfieldcivic
15
Jun 24, 2005 02:26 PM
