2 simple question
Old Jun 9, 2007 | 12:17 PM
soon2bdropped's Avatar
Default 2 simple question
oil leaking from head and block on h22.. i know its the headgasket but will it cause compression lost.. and what about is there a chance that oil and coolant might mix or no? just the gasket isn't seated right? right?
also which valve is hotter.. intake or exhaust.. i'l say exhaust since its letting hot burnt air oout,.. but intake could be hot during power stroke.
Old Jun 9, 2007 | 12:32 PM
JDM_DC4_Fanatic's Avatar
Default Re: 2 simple question (soon2bdropped)
if the head gasket is leaking you will lose compression. Depending on where the gasket is broken, the oil can leak into the coolant passage, or vise versa, the coolant can leak into the oil pan.
Both valves are the same temp since they are both in the combustion chamber, and are both exposed to the compression and ignition of the fuel.
Old Jun 9, 2007 | 12:45 PM
Alpinestar03's Avatar
Dude, ive dicussed all of this with you via IM like a month ago. LOL.
And yes you will probally find a mix of coolant/oil. If your getting coolant in your oil id fix the HG asap. The water will rust the bearings and your bottomend will be toast.
-Eric
Old Jun 9, 2007 | 01:46 PM
Default Re: 2 simple question (JDM_DC4_Fanatic)
i did compression test and all the numbers are good.. doesmn't misfire or run rough.. explain how i lose compression when all its doing is letting oil seep out of the gasket..
Old Jun 9, 2007 | 02:13 PM
Dude i explained it to you before.
In the case of a blown head gasket burning/leaking, excange of oil/coolant. Theres a small gap between the head, HG, and the block. Thus creating a small passage (thousanths of an inch) for the compressed gases to leak through. Your compression may seem to be good with a normal compression test but you can really tell with a leak down test.
http://www.type2.com/library/engineg/leaktst.htm
Get a new HG and get your head milled (60-80 bucks). And your set!
-Eric
1320london
May 15, 2015 06:47 AM
avotegra
Dec 13, 2009 11:45 PM
lakerschamp2000
Apr 20, 2009 10:51 AM
beutler09
Jan 4, 2009 01:15 AM
an2ny888
Jul 4, 2008 07:40 AM
