code 15 after changing ignition switch
Old Jun 9, 2007 | 11:47 AM
abelacha's Avatar
Default code 15 after changing ignition switch
My car has been getting bad mpg since I changed the ignition switch (6 weeks). The mechanic said the switch contacts had worn. I have been getting bad mpg ever since. The ecu throws code 15 and code 13.
I drove the car thrice while holding the key in the start position when the switch was not working (my mistake) but the starter is running fine. Could this be the ignitor or something else?
Also, there is motor oil inside the spark plug housing. The wire plugs are drenched in oil. Is this a bad sign?
93 accord lx 4dr
Old Jun 10, 2007 | 09:06 AM
hondadude's Avatar
Default Re: code 15 after changing ignition switch (abelacha)
Link for you;
http://members.troublecodes.ne...s.txt
Oil in the spark plug tubes means you need a valve cover gasket Kit
flipintentionz
Aug 24, 2020 06:18 AM
joshua89
Jul 30, 2011 01:36 PM
allmotor2.1
Nov 17, 2007 05:01 AM
22lude
May 2, 2005 05:59 AM
Patch
Jun 8, 2003 04:14 PM
