Suspension & Brakes Theory, alignment, spring rates....
Koni Perches
Old Jun 9, 2007 | 08:10 AM
Partizan's Avatar
Default Koni Perches
Hey guys, im about to install my koni yellows. I got some H&R springs to go with them, and i want the springs to drop the car the ammount they said they would. What perch should they be set on? The front shocks have two, and the rear have three perches. All for 96 civic coupe.
Old Jun 9, 2007 | 08:54 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Koni Perches (Partizan)
top perch on the front, middle perch on the back.
To be sure, though, just put them in that position and them compare them side-by-side with your OEM shocks.
Old Jun 9, 2007 | 02:57 PM
Partizan's Avatar
thanks, can anyone else confirm?
Old Jun 9, 2007 | 09:52 PM
Community Builder
I believe the instruction sheet that came with my Koni shocks indicated that top in front is stock, and middle in back is stock.
I'm using stock springs on the lowest perch height all around and it's way lower than stock.
Old Jun 10, 2007 | 12:00 AM
power11's Avatar
Default Re: (PatrickGSR94)
getting aftermarket shocks can lower your car even more?
Old Jun 10, 2007 | 06:06 AM
Community Builder
if you have shocks like Konis with adjustable perch height settings, then yes
Old Jun 12, 2007 | 10:58 AM
snowboardgeek1's Avatar
I have mine set at the middle perch settings. That's what the instructions said to set it at.
Old Jun 12, 2007 | 11:02 AM
Community Builder
Default Re: (snowboardgeek1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowboardgeek1 &raquo;</TD></TR><TR><TD CLASS="quote">I have mine set at the middle perch settings. That's what the instructions said to set it at.</TD></TR></TABLE>
Unless you have Neuspeed Konis, there is no middle for the front shocks, only top or bottom. Top is the stock setting if that's what you want.
Old Jun 15, 2007 | 09:39 PM
Partizan's Avatar
cool thanks
PatrickGSR94
Suspension & Brakes
Oct 28, 2006 11:35 PM
J-HAWK
Feb 25, 2006 06:22 PM
caquinyoface
Jul 25, 2003 05:22 PM
FBP Ex-T
Feb 19, 2002 05:34 PM
