whats the lenght of the 14mm 1.25mm thread Crank shaft pulley bolt??
Old Jun 9, 2007 | 07:02 AM
mattsnooz's Avatar
Default whats the lenght of the 14mm 1.25mm thread Crank shaft pulley bolt??
The length of the crank shaft pulley bolt and And if you know the regular "grade" of the OEM part that would help! Also if you know anybody that sells those bolts for the crank (aftermarket and stronger like grade 10 or 12 preferably)
im looking to do some preventative work on crank shaft so i don't repeat my last car's crank failure.
Old Jun 9, 2007 | 06:32 PM
mattsnooz's Avatar
Default Re: whats the lenght of the 14mm 1.25mm thread Crank shaft pulley bolt?? (mattsnooz)
anybody? Im going to bump this once atleast. im hitting a nuts and bolts supplier (fastanal etc) and i want to buy a higher grade crank pulley bolt without having to take it off just yet! anybody know grade of OEM crank pulley bolts too??
alex14
13
Dec 10, 2010 09:28 AM
KCUF_DB8
Apr 2, 2010 09:18 PM
PreludePhill
Sep 10, 2007 04:59 AM
ent1016
Aug 8, 2004 02:50 PM
