ITR vs GSR blocks
Old Jun 8, 2007 | 11:42 PM
Syndacate's Avatar
Default ITR vs GSR blocks
Let me just start this with I know that it can be searched - I just don't feel like sifting through some crap over this as it's damn near 4a, I'm tired, and I g2 deal w/ this relatively early on a tight sched .
Basic rundown:
Building a motor for boost, fully built GSR block, w/ lower compression pistons, ITR crank, and ITR head (ITR IM too).
Is there anything else I'm missing to make this what's basically "an ITR" motor? Obviously the internals are diff but it's been bored and sleeved and rods/pistons are diff, so basically just ignore them.
Is everything set to go or are there more ITR parts missing?
Old Jun 9, 2007 | 09:34 AM
preludedriva's Avatar
itr crank is the same as a gsr crank btw
crank pulley is different
itr tranny
thats bout it
Old Jun 9, 2007 | 09:38 AM
DonF's Avatar
Default Re: (preludedriva)
ITR crank is heavier than a GSR as it has larger counter-weights. The dimensions are the same.
Old Jun 9, 2007 | 11:14 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludedriva &raquo;</TD></TR><TR><TD CLASS="quote">itr crank is the same as a gsr crank btw
itr tranny
thats bout it</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">ITR crank is heavier than a GSR as it has larger counter-weights. The dimensions are the same.</TD></TR></TABLE>
Yeah, crank pulley's ITR too - at least I think, came w/ the ITR crank from the ITR engine that it was in.
As for the trans it's an ITR/B16 with an even shorter final drive.
So that's it, it's ready to roll?
Old Jun 9, 2007 | 09:55 PM
doood's Avatar
been there done that
Default Re: ITR vs GSR blocks (Syndacate)
other than the rods, crank, and pistons, c1's and c5's share the same block
Old Jun 11, 2007 | 11:34 AM
Syndacate's Avatar
Default Re: ITR vs GSR blocks (doood)
Thank you very much.
Old Jun 12, 2007 | 05:57 AM
kevinz's Avatar
don't forget the red valve cover
Mr HYDE
Dec 20, 2006 12:00 AM
Tech6023
Sep 21, 2005 09:15 PM
vtecmonster001
Feb 20, 2005 03:53 PM
vtecmonster001
Feb 14, 2005 04:34 AM
Odiedogcx
Oct 21, 2004 04:29 PM
