Cat and O2 Sensor Recommendations
Old Jun 8, 2007 | 11:07 PM
elmo908's Avatar
Default Cat and O2 Sensor Recommendations
I am asking for recommendations from any fellow hondatechers out there to recommned any online sources for well priced quality catalytic converters and oem fitment oxygen sensor. I have successfully swapped a 94 b18b into my 93 civic vx and want to get my car running clean, this is the first honda vehicle I have worked with and have found it to be fairly simple up to now. Any help would be appreciated. Thanks.
Old Jun 9, 2007 | 07:06 AM
ricekiller1's Avatar
Default Re: Cat and O2 Sensor Recommendations (elmo908)
need similar info...^^^bump^^^ ???good aftermarket o2 sensors???
Old Jun 9, 2007 | 08:45 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
For oxygen sensors, you can try sparkplugs.com. 10% discount code: srto2.
Don't know about the cat though.
Old Jun 9, 2007 | 09:55 AM
elmo908's Avatar
Thanks for the recommendation. If anyone can recommend a good, cheaper than dealership oem-fit cat supplier, that would be awesome. Thanks
Old Jun 9, 2007 | 10:03 AM
Default Re: (elmo908)
are honda o2 sensors nkg or denso???? if not what are they? anyone?
Old Jun 9, 2007 | 05:28 PM
elmo908's Avatar
my guess would be denso but any good info would be welcome on this thread.
Old Jun 12, 2007 | 04:12 PM
SpoonEk253's Avatar
http://hondamarketplace.com/zerothread?id=1890859
Old Jun 12, 2007 | 04:40 PM
boots420's Avatar
Default Re: (ricekiller1)
oem is denso. sparkplugs.com is the place. i got mine for 60 shipped next day air.
Old Jun 12, 2007 | 06:55 PM
noss88's Avatar
Default Re: (boots420)
im thinking of changing my o2 sensor...but i dont know much about cars...how can i tell if i should change it?
Old Jun 12, 2007 | 06:58 PM
dannis.'s Avatar
Default Re: (noss88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by noss88 &raquo;</TD></TR><TR><TD CLASS="quote">im thinking of changing my o2 sensor...but i dont know much about cars...how can i tell if i should change it?</TD></TR></TABLE>
if you still have your stock ecu it should throw a code when its bad.
Old Jun 13, 2007 | 10:03 AM
boots420's Avatar
Default Re: (dannis.)
if its bad you'll see your check engine light on. no need to replace it if there is no problem. that thing is a bitch to change. last time i changed my o2, it stripped the bung round when i took it out. pain in the ***. believe me.
RigaTony
Apr 26, 2011 02:54 PM
rjmq06
Sep 12, 2010 03:05 PM
Baron55
Mar 7, 2007 07:12 AM
shivers
Apr 19, 2002 06:05 AM
