how to: b16a 58mm throttlebody to d16z6 intake manifold
the b16a obd0 throttle body is a bolt on upgrade good for 2-5 whp. even more on boosted apps,
the only ptoblem i had with the swap was the map sensor so ill ocver how to source vacumn to the firewall and relocate the map alos great if you are wire tucking
cleans up an ugly sensor and a whole subharness of 5 or so wires
also it has a wiered vacumn thing called the fast idle control valve, just ignore this, and try your best to plug it if you want
this is a 58mm throttle body not a 60mm throttle body, all other b series tb's arent as complicated as this swap and are 2 mm bigger, i had this lying around and was in the middle of a wire tuck and just did it
heres the d16z6 tb
and here are teh tb sensors for those newbs out there
i dont have a pic of it, but what i just did is t off the pcv vacumn line and ran it to the nipple on the map sensor and hid the map sensor
kinda like this
thats it lmao, sorry for not having alot of pics of what im talking about but itspretty simple just run an extra vaucumn line to the map snesor that has been relocated, it will clean your bay up alot
heres the d16z6 tb
kinda like this
ummm...ok write i guess...is this a direct bolt on to the z6 manifold? i thought it wasnt.
or you could just spend 100 bucks and get it bored out to 60mm
http://www.maxbore.com
How does it help at all without port matching the intake manifold?
All I can see it doing is creating more turbulence, maybe subtract that 5 or 10hp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">How does it help at all without port matching the intake manifold?
All I can see it doing is creating more turbulence, maybe subtract that 5 or 10hp.</TD></TR></TABLE>
my engine:
-d16z6 gasket matched everything
-subtracted all edges in rotating assy
-weisco's edges removed mirror fase scuffed
-eagle rods
-stock crank
-stock sleeves
-greddy manifold
-t25 turbo
-30 psi
-crome
-b16a obd 0 tb
-moroso oil pan
-magnetic drain plug
-arp bolts rod and head
your engine i/h/e
edit: lobsterdo you know waht gasket matching is? ill make a write up on that too
easy way to get some horsepower and cheap
Modified by 951BRO at 11:32 AM 6/9/2007
my engine:
-eagle rods
-stock crank
-stock sleeves
-greddy manifold
-t25 turbo
-30 psi
-crome
-b16a obd 0 tb
-moroso oil pan
your engine i/h/e
easy way to get some horsepower and cheap Modified by 951BRO at 11:32 AM 6/9/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 951BRO »</TD></TR><TR><TD CLASS="quote">
my engine:
-eagle rods
-stock crank
-stock sleeves
-greddy manifold
-t25 turbo
-30 psi
-crome
-b16a obd 0 tb
-moroso oil pan
your engine i/h/e
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">How does it help at all without port matching the intake manifold?
ok so hes right you are losing HP since you didnt get it port matched. Your gasket might of been matched by now its like hitting a wall when it passes the TB hitting all those edges.
my engine:
-eagle rods
-stock crank
-stock sleeves
-greddy manifold
-t25 turbo
-30 psi
-crome
-b16a obd 0 tb
-moroso oil pan
your engine i/h/e
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">How does it help at all without port matching the intake manifold?All I can see it doing is creating more turbulence, maybe subtract that 5 or 10hp.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cooper. »</TD></TR><TR><TD CLASS="quote">what a time bomb that thing is; stock sleeves 30psi; on a t25. talk about out of efficiency range of that turbo.</TD></TR></TABLE>
hahah junkyard turbo at its finest, the brakes are out right now but it was holding up for a while, and if it blows..............................k swap!!!!!!!!!
RedRacerCivic
Aug 10, 2004 04:11 PM
silos
Apr 25, 2003 06:50 AM
