rev limiter
Old Jun 8, 2007 | 07:31 PM
Slo_Accord's Avatar
Default rev limiter
i was wondering if there is any way to take off the rev limiter of a 97 accord. it doesnt go pass 4 rpm or sumtin like that in 5th. just wanderin
Old Jun 8, 2007 | 10:53 PM
professorman's Avatar
Default Re: rev limiter (Slo_Accord)
yep, there is a wire you can cut, I have it saved on my other computer. I decided that was information I didnt need to know though. It sound like something is wrong with your car though. Not being able to rev past 4k RPM. That is pretty high speeds though, isnt it? At about 60MPH, I'm reving at about 2 - 2.25 RPM in 5th gear.
The-Kid's Avatar
4K? never heard of that. Heck I rev my auto to the redline fine. Ummm *bump* for the answer.
Old Jun 9, 2007 | 06:49 AM
AFAccord's Avatar
Default Re: rev limiter (The-Kid)
Are you trying to rev an automatic in park or neutral?? Or is this while in drive, going down the road?
Old Jun 9, 2007 | 06:53 AM
AFAccord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slo_Accord &raquo;</TD></TR><TR><TD CLASS="quote"> it doesnt go pass 4 rpm or sumtin like that in 5th. </TD></TR></TABLE>
You say 5th, so i'll assume it's a manual, and you can't go past 4K? Is the car an EX, LX, DX? You're either hitting the aerodynamic wall that your car doesn't have enough power to push past, or you're hitting the speed governor. Both are forms of idiot protection, though obviously they're not enough.
Old Jun 9, 2007 | 11:54 AM
Slo_Accord's Avatar
Default Re: rev limiter (AFAccord)
i can do 2.5 doin 60 fine. i mean like over 110 in fifth. it will go up then just stops at 4 thousand. lx 5 speed manual
Old Jun 9, 2007 | 12:24 PM
Alpinestar03's Avatar
Its the speed limiter.. I wouldnt reccomend going that fast on a public road at all. It is HIGHLY dangerous and reckless..
I do have an ecu from a 92 accord ex that doesnt have a speed govener. If you want a price PM me.
-Eric
Old Jun 10, 2007 | 09:14 AM
hondadude's Avatar
Check engine light on?
if you are running the ECU in default you can't rev up.
Old Jun 10, 2007 | 10:32 AM
project95cd's Avatar
Default Re: rev limiter (hondadude)
My car was doing the same but turns out my tach was off but 500-800rpms. I put a checkengine shiftlight in my ecu(p28 w/ chrom) at like 6200 and it always came one around 5500. I've been curious what my car can rev too with stock internals in both head and block without blowing or floating a cam but that may need to be another thread. your most likely hitting a speed limiter.
Old Jun 10, 2007 | 11:13 AM
Its not good to rev our engines with stock internals past 6K. They dont make any power past 6000.
Old Jun 10, 2007 | 01:14 PM
AFAccord's Avatar
Default Re: rev limiter (project95cd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project95cd &raquo;</TD></TR><TR><TD CLASS="quote">I've been curious what my car can rev too with stock internals in both head and block without blowing or floating a cam but that may need to be another thread. your most likely hitting a speed limiter. </TD></TR></TABLE>
Valve lash will be your first opponent, but shortly after, the entire bottom end is prone to fail due to oil starvation.
Old Jun 10, 2007 | 06:36 PM
Schmitey's Avatar
Damn! Is it just me or is it alarming how many people DON"T READ THE INITIAL POST and/or don't realize he's hitting his top speed limiter? Freaking read people!
Old Jun 11, 2007 | 06:33 PM
Default Re: rev limiter (Schmitey)
The speed governor on the LX accord is 115MPH. My tach bounces. I did it once on a track. I found out how to remove it, but I would never go that fast on the road, so I dont really need it.
The-Kid
Mar 5, 2007 04:20 PM
fandirabbani08
Honda Civic (2006 - 2015)
Feb 16, 2007 12:47 PM
bseries_beast
Dec 30, 2004 02:15 PM
osuperjohno
May 3, 2004 07:54 PM
Loveless
Jun 23, 2003 09:40 PM
