a little help for an EF guy... please?
Old Jun 8, 2007 | 05:14 PM
Hondamonster's Avatar
Default a little help for an EF guy... please?
im doing a mini me in my crx with a z6 head. after hooking up my vacuum lines i still have the map sensor line and nothing to put it on. on the top of my throttle body there are two screw holes with a bigger hole in the middle... like this oOo
is there suppose to be something there to put the map sensor vacuum line on? thanks
Old Jun 8, 2007 | 05:32 PM
Default Re: a little help for an EF guy... please? (Hondamonster)
anybody? i just figured yall would know since that motor comes in your cars...
Old Jun 8, 2007 | 05:34 PM
Libertariat's Avatar
Ek Forever y0!
Well, the guys in the EF forum probably know better since they do that swap.
the z6 doesn't have a map sensor, so just leave it unplugged.
Old Jun 8, 2007 | 05:43 PM
pdiggitydogg's Avatar
Sure the z6 has a map sensor
The older hondas had maps that were firewall mounted, with a vacuum line atop the TB, right?
Well later, maps were installed directly on top of the TB itself - thats what your holes are.
You could probably just tap the center hole and add a brass barb fitting. (it would probably have to be NPT tap'd since I dont know too many std size threaded fittings)
That way, you could attach a vac line from your firewall map
Old Jun 8, 2007 | 06:00 PM
Ek Forever y0!
Default Re: (pdiggitydogg)
^^ that's right, it didn't occur to me they're usually mounted on the firewall.
So it's likely he can just swap his old map sensor or get a new one and put it on the mounting holes on the TB.
Old Jun 8, 2007 | 06:10 PM
Default Re: (ek forever guy)
ok thanks guys
Old Jun 8, 2007 | 06:25 PM
i really dont know if a new-style map is an option - the connectors may be different
easy to get a map
hard to get a connector
Old Jun 8, 2007 | 07:59 PM
sauceja's Avatar
Honda map sensors are the same. They run on voltage signals.
Only differences are some are firewall mounted and some are TB mounted.
Old Jun 8, 2007 | 09:46 PM
HiProfile's Avatar
Default Re: (sauceja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceja &raquo;</TD></TR><TR><TD CLASS="quote">Honda map sensors are the same. They run on voltage signals.
Only differences are some are firewall mounted and some are TB mounted.</TD></TR></TABLE>
That, and obd0 MAP sensors (Honda 1.75bar) have a slightly different diaphram style, and read a little less max boost. Your stock MAP will work fine as long as the vacuum line is hooked to the manifold. The FPR line is fine to tee off of, as long as its not a very modified 'beast' of a motor, as much as a D16 can be. I'd just take a chunk of 1/8" aluminum (road signs are perfect for this) and an o-ring, then get some metric screws to bolt it over the center hole. They're like M5x0.6 or some oddball size.
protopro88
Apr 30, 2012 06:39 PM
89CivicHb1
Sep 13, 2008 02:44 PM
175Shot4Door
Mar 2, 2007 08:26 AM
90b20vteckidd
17
Sep 27, 2006 06:03 PM
madswapper
Jun 1, 2005 05:13 PM
