i got question about doing mini me swap
Old Jun 8, 2007 | 02:46 PM
foowitdaredek's Avatar
Default i got question about doing mini me swap
kk well im going to be using a z6 head on y7 block. i got the head with intake manifold and a dizzy. my question is can i use the fuel rail, fuel injectors and throttle body from the y7???
Old Jun 9, 2007 | 05:45 PM
96hatchy's Avatar
Default Re: i got question about doing mini me swap (foowitdaredek)
i would just buy the new stuff even if u could use the y7 stuff. get either stock or aftermarket. a skunk2 manifold is like 225 on robearracng.com
dont rush things b/c it turns out rigged,unreliable, and lookin horrible.
Old Jun 9, 2007 | 07:45 PM
hatchnideas's Avatar
you will want to use the intake manifold from the z6, throttle body from the y7 is fine; y7 injectors are supposed to be 190cc while z6 are 240cc so no on the y7's; im not sure about fuel rail. dont forget the ecu and iacv fix depending on what car you are working with.
Old Jun 9, 2007 | 10:07 PM
i have the ecu already.. oh yeah what about the timing belt should i get one for the z6??
Old Jun 10, 2007 | 12:03 AM
minime-civic's Avatar
* B A N N E D *
yes, everything will work, and all the pllugs are the same on the vtec head as they are on a non vtec, be sure u pulll out the oil plug from the intake side of the block, and get a vtec timing belt... u should be all set
doncapiku
May 18, 2016 10:29 AM
BuildingUp
Sep 16, 2010 06:04 AM
SOHC_civic_si
May 20, 2008 02:46 PM
gnar kill
Mar 22, 2005 10:26 AM
photonjedi808
Jul 21, 2002 02:25 PM
