How to adjust clutch pedal?
Old Jun 8, 2007 | 01:07 PM
team 15's Avatar
Default How to adjust clutch pedal?
same as topic for a 97 civic dx hb. My clutch is soft. I bled it and still soft.
Old Jun 8, 2007 | 02:08 PM
dannis.'s Avatar
Default Re: How to adjust clutch pedal? (team 15)
Im pretty sure that you can't adjust the cltuch pedel on a hydro tranny. someone correct me if im wrong.
Old Jun 8, 2007 | 04:20 PM
team 15's Avatar
Default Re: How to adjust clutch pedal? (dannis.)
i heard that you can adjust the ckutch pedal from the inside of the car next to the clutch pedal.
Old Jun 8, 2007 | 04:21 PM
92ehatch's Avatar
you can, its been covered. lemme find the thread wehre i last explained it so i dont have to retype...
Old Jun 8, 2007 | 04:23 PM
92ehatch's Avatar
Default Re: How to adjust clutch pedal? (92ehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch &raquo;</TD></TR><TR><TD CLASS="quote">you can adjust the clutch by turning the plunger/rod that attaches ot the pedal.
go under the dash.
find the clutch
find the rod attached to the pedal
loosen lock nut
turn the rod (not sure which direction raises/lowers engagement mabey someone else will chime in with that answer,or just test it and find out)
tighten lock nut
test.</TD></TR></TABLE>
Corksil
Oct 31, 2011 03:59 PM
93hatchattack
Sep 14, 2007 06:38 AM
mikeycivic
May 23, 2007 02:34 PM
acmeotally
Jul 29, 2005 09:32 AM
jdmcivicferio
Nov 12, 2003 06:02 AM
