vtec issue
Old Jun 8, 2007 | 10:50 AM
Hatchman98's Avatar
Default vtec issue
i have a b16a jdm motor in a 98 hatch. I have all the wiring done and the swap is done and runs fine except for vtec. It shows a code for the vtec selonoid, all the wiring is correct from what i checked, does it sound like a bad selonoid?? its a obd2 harness with a seperate vtec line ran from the selonoid. And its also jumped from obd2-1 at the ecu w/ a jumper harness
Old Jun 8, 2007 | 10:53 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: vtec issue (Hatchman98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchman98 &raquo;</TD></TR><TR><TD CLASS="quote">i have a b16a jdm motor in a 98 hatch. I have all the wiring done and the swap is done and runs fine except for vtec. It shows a code for the vtec selonoid, all the wiring is correct from what i checked, does it sound like a bad selonoid?? its a obd2 harness with a seperate vtec line ran from the selonoid. And its also jumped from obd2-1 at the ecu w/ a jumper harness</TD></TR></TABLE>
Got any buddies with a working vtec solenoid? Swap them out and see if the code goes away or if the problem is solved.
Old Jun 8, 2007 | 11:56 AM
ddd4114's Avatar
Default Re: vtec issue (ek forever guy)
You could also hook the solenoid up to a 12V source and listen for a click.
Old Jun 17, 2007 | 05:23 PM
CCCPRB's Avatar
i have the same prob but my solenoid works
Old Jun 17, 2007 | 09:15 PM
mars-EF-LS's Avatar
Default Re: (CCCPRB)
This is a question out of the box but I want to go ls vtec and I'm new at this honda stuff. But I have a 93 civic coupe and I want to do a swap but I was just stopping by to see what you guys suggestion on, if I put a b16b head on a b18b is cheap easy installation I prartically need the whole info pleas and thanks.
Old Jun 17, 2007 | 09:26 PM
96teggylsse's Avatar
Default Re: (marsvtec)
you need to hook up a light to your 12v wire that goes to you solenoid and see if it lights up when your vtec should engage if not then i dunno... if it does light up then you need a new solenoid... also try to hook up 12v to your solenoid and see if you can hear a click... if you do then your soleniod is good
ZanderGTS's Avatar
^^Way to jack anothers post!!! START YOUR OWN!^^
Old Jun 19, 2007 | 09:38 PM
Default Re: (ZanderGTS)
^^^^^^^^ im here to help dumbass!!!
Old Jun 19, 2007 | 09:39 PM
Default Re: (96teggylsse)
lol no ****!!! there is plenty of space for you.... just somewhere else!!!
x4thGenCafe
18
May 14, 2008 08:28 PM
Hatchman98
Jun 26, 2007 01:28 AM
kornerk12
Apr 19, 2007 08:41 PM
spyderracing
22
Sep 18, 2004 05:43 AM
baonest1
Feb 11, 2003 06:11 AM
