How is your clutch pedal
i have a eg civic and ever since i own it, i have never replaced the clutch,
whenever i step on the clutch pedal, i wont feel any pressure for the first half inch.
does this happen to you guys too?
thank you
thank you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">i have a eg civic and ever since i own it, i have never replaced the clutch,
thank you</TD></TR></TABLE>
First thing i would is bleed the clutch. If it still persist then try adjusting your clutch pedal bro. There is a bolt on the clutch master cylinder on the inside of your car. Look under the dash towards the firewall...you can't miss it, it connects with your clutch pedal.
i believe there is a DIY on this
Dont quote me on this, but I've heard that it is normal for the first 1/4'' - 1/2'' to be "loose" and have no pressure.
I have an Exedy Organic Racing Clutch, and mine is just like that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaluwa3 »</TD></TR><TR><TD CLASS="quote">I have an Exedy Organic Racing Clutch, and mine is just like that.</TD></TR></TABLE>
x2
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaluwa3 »</TD></TR><TR><TD CLASS="quote">it is normal for the first 1/4'' - 1/2'' to be "loose" and have no pressure.
x2
no need or reason to start bleeding the clutch lines or checking the master cylinder... Geez, some up you people really jump the gun don't you?
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr x civic »</TD></TR><TR><TD CLASS="quote">i don't see it being too big of a problem. a little play isn't bad. </TD></TR></TABLE>
exactly why i said this
LSEGHATCH
May 2, 2006 06:18 AM
