Do I need a deep sump, pre-taped oil pan for my turbo setup? *thinkin about an obx one*
Old Jun 8, 2007 | 09:51 AM
whole9's Avatar
Default Do I need a deep sump, pre-taped oil pan for my turbo setup? *thinkin about an obx one*
Or will the stock one, custom tap'd work perfectly fine?
Anyone have an OBX oil pan and have any vouches for it's quality?
Old Jun 8, 2007 | 09:54 AM
90sedan's Avatar
Get your stock pan tapped.
Old Jun 8, 2007 | 03:39 PM
whole9's Avatar
Default Re: (90sedan)
It is cheaper, thats for sure!
Old Jun 8, 2007 | 04:11 PM
89efDUSTY's Avatar
Default Re: Do I need a deep sump, pre-taped oil pan for my turbo setup? *thinkin about an obx one* (whole9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whole9 &raquo;</TD></TR><TR><TD CLASS="quote">Or will the stock one, custom tap'd work perfectly fine?
Anyone have an OBX oil pan and have any vouches for it's quality? </TD></TR></TABLE> for sure you can go stock, just be sure to get it on the deeper side of the pan, and make sure you mount it as high up as possible, because gravity is the only force moving the oil in the return line; after its been fed of course.
Old Jun 9, 2007 | 06:33 AM
whole9's Avatar
Default Re: Do I need a deep sump, pre-taped oil pan for my turbo setup? *thinkin about an obx one* (89efDUS
just wondering still about the quality of the obx.
Old Jun 9, 2007 | 10:45 AM
D16Z6racing's Avatar
Do you have a link to the OBX pan?
Still I'd stay OEM. But I'd get another OEM pan too. So when/if you ever take the turbo off you don't have to seal off the tap or cork it. You'll always be set not having to do work over and over on the same pan.
Old Jun 11, 2007 | 09:35 AM
whole9's Avatar
Default Re: Do I need a deep sump, pre-taped oil pan for my turbo setup? *thinkin about an obx one* (D16Z6ra
it looks just like moroso
Frost7177
Aug 30, 2009 09:37 AM
josh0407
Aug 24, 2007 04:30 PM
EJ8 GSR-T
11
Jan 3, 2006 08:34 AM
Layziebtnh055
May 16, 2004 10:09 AM
Steve91
May 29, 2003 08:43 AM
