Bad Starter?
Old Jun 8, 2007 | 05:41 AM
IIXtremeHansen's Avatar
Default Bad Starter?
This morning i turn the key over and there is no starting sound. just silent, battery seems fine. so is it the starter that need to be replaced?
Old Jun 8, 2007 | 06:01 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Bad Starter? (Dickies_N_FlipFlops)
Could be your main relay too.
Or your battery/grounds
Old Jun 8, 2007 | 06:18 AM
mikeycivic's Avatar
Default Re: Bad Starter? (ek forever guy)
usually bad starter = fast clicking sound when you turn the key. How do you know the battery is good? Did you try to jump start the car?
Old Jun 8, 2007 | 06:24 AM
Default Re: Bad Starter? (mikeycivic)
yeah i jumpued started it, nothing. radio,alarm works. but i might just take it to autozone to check the battery
so symptons of a bad starter is clicking over fast?
Old Jun 8, 2007 | 06:26 AM
mikeycivic's Avatar
your radio and alarm do work?
Old Jun 8, 2007 | 06:28 AM
yes
Old Jun 8, 2007 | 06:34 AM
mikeycivic's Avatar
check the two wires coming from the starter and make sure they are not loose, check fuses, I know there is a way to bypass the starter to start the car but I am not sure how to do it. Someone will chime in soon and have an answer. Your starter may be bad though.
Old Jun 8, 2007 | 06:37 AM
Ek Forever y0!
Also, if your starter dies the starter itself will actually smoke.
Old Jun 8, 2007 | 06:56 AM
it was working last night till this morning, turn the key over and nothing, no turn over sound, nothing
Old Jun 8, 2007 | 06:59 AM
mikeycivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikeycivic &raquo;</TD></TR><TR><TD CLASS="quote">check the two wires coming from the starter and make sure they are not loose, check fuses, I know there is a way to bypass the starter to start the car but I am not sure how to do it. Someone will chime in soon and have an answer. Your starter may be bad though. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Could be your main relay too.
Or your battery/grounds</TD></TR></TABLE>
Old Jun 8, 2007 | 07:36 AM
jdb2527's Avatar
i had the same problem, pop the clutch and take it to a shop, they put mine on a lift to see underneath and a wire for the starter had come loose. easy fix took them 10 minutes
Old Jun 8, 2007 | 08:12 AM
crazyguy's Avatar
same thing happen to me once..
i hot wired the starter but nothing happened.so i knew it was broken
replaced a newer one and fires right up.
only 2 bolts to loose and tighten.
easy job
Old Jun 8, 2007 | 08:23 AM
YodajdmEK4's Avatar
Default Re: Bad Starter? (crazyguy)
Could be main relay, or loose wire. Check for all that if not its the starter
threesix36's Avatar
first check if the batt has voltage over 12v, if you dont have above 12v replace batt, if you do then check to make sure you have power running to the starter. if you don have voltage to the starter you need to inspect your wiring form the batt to the starter for an open circuit. if you have voltage to the starter then try hitting the starter sylenoid with a hammer or heavy object, the starter might be bound, try starting after giving a couple good whacks, if it doesnt start then reaplce the starter.
Old Jun 8, 2007 | 10:00 AM
instructor74's Avatar
Default Re: Bad Starter? (threesix36)
[QUOTE= try hitting the starter sylenoid with a hammer or heavy object, the starter might be bound, try starting after giving a couple good whacks, if it doesnt start then reaplce the starter.[/QUOTE]
Even if it does start replace the starter before it completely sh$#s the bed
Old Jun 9, 2007 | 06:55 AM
could the ignigtion switch be the problem, test light it and it all seems fine, wahts the symptons of a bad start switch, took out the 2 screws and turn it over and nothing. i think it works though because it is getting signal
Modified by Dickies_N_FlipFlops at 8:11 AM 6/9/2007
Old Jun 9, 2007 | 06:59 AM
mikeycivic's Avatar
yes could be bad ignition switch as well
Old Jun 9, 2007 | 07:12 AM
only way to start it is hot wirre from the engine bay
Old Jun 10, 2007 | 02:04 PM
iunno everything seem to get signal but its not sending power or enough power to the relay so i rigged it up put a bigger wire and boom it start when i turn the ignition on. it must be a broken line or shortage somewhere.
Old Jun 10, 2007 | 09:36 PM
Sean DM's Avatar
im havingt this same problem with my car!
Old Jun 11, 2007 | 06:15 AM
Default Re: Bad Starter? (Sean DM)
what have you checked?
Old Jun 11, 2007 | 08:08 AM
jdb2527's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dickies_N_FlipFlops &raquo;</TD></TR><TR><TD CLASS="quote">only way to start it is hot wirre from the engine bay</TD></TR></TABLE>
You mean you can't simply pop the clutch? Just park on a hill everywhere you go and you'll be fine.
Old Jun 11, 2007 | 08:10 AM
Ek Forever y0!
Default Re: Bad Starter? (jdb2527)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdb2527 &raquo;</TD></TR><TR><TD CLASS="quote">
You mean you can't simply pop the clutch? Just park on a hill everywhere you go and you'll be fine. </TD></TR></TABLE>
Old Jun 11, 2007 | 09:51 AM
Bejita's Avatar
Make sure the little wire thats goes to the starter is connected. If it's comming loose it will cause this problem. Not the big wire from the battery. The little tiny wire at the top with the little connector.
Old Jun 11, 2007 | 10:28 AM
aww yeah of course, but its fixed now, rigged it up
everything gives signal except the 2 plugs where the tach wire is. i check it with the test light and no signal when i crank,i think there a break between the relay under the steering wheel and to the ignigtion.
jgett002
Aug 3, 2016 02:00 PM
azandford
Apr 29, 2010 06:03 AM
lilsol89
Jan 5, 2009 03:57 PM
Touge Tuning
May 3, 2006 11:14 AM
mingchi69
Jul 14, 2003 06:14 PM
