Noise from rear
Car:
2001 Honda Accord EX 4cyl 4dr M/T @ 104,538 miles &
I cannot tell in my driver's seat if the noise is coming from rear left rear or rear or both but its is a buzzing / humming noise, and as i increase speed the pitch increases. It is always constant, does NOT go away or get louder when i take turns.
It started a while ago, maybe 500-600 miles and gas gradually increased. Also if I pull the hand brake on the freeway just enough to start slowing car down the noise disappears until the pressure is relieved.
Do I need to rotate my tires or is it wheel bearings as i suspect?
Can some moderator bump this thread to Accord instead. I mis-posted it.
Also- I doubt it is fuel pump as it only makes sound when i drive and not stand and the pitch does not increase as i Rev the engine but as speed increases.
