changing fuel filter
Old Jun 7, 2007 | 09:35 PM
20ls01's Avatar
Default changing fuel filter
do i have to remove rear seats to change the filter filter?
Old Jun 7, 2007 | 09:37 PM
92 gs INTEG's Avatar
Default Re: changing fuel filter (20ls01)
isnt in ur engine bay, on the fire wall correct. it is on my DA9
Old Jun 8, 2007 | 05:33 AM
int3gra07's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20ls01 &raquo;</TD></TR><TR><TD CLASS="quote">
it is but this article says something about unplugging the fuel pump electrical connector
http://www.team-integra.net/se...D=391
cant i just unplug the battery?
I just changed my filter last month. I know the haynes says to disconnect the fuel pump connector under the rear seats. I didn't do that. All I did was release pressure from the gas cap and disconnected the battery then I swapped the bad filter. Never had any problem since.
Old Jun 8, 2007 | 05:39 AM
94 IntegraLS's Avatar
Default Re: changing fuel filter (int3gra07)
^^ I did the same thing on my DB7... just make sure you install it right and you should be all set to go.
Old Jun 8, 2007 | 05:40 AM
JmurGSR98's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by int3gra07 &raquo;</TD></TR><TR><TD CLASS="quote">
I just changed my filter last month. I know the haynes says to disconnect the fuel pump connector under the rear seats. I didn't do that. All I did was release pressure from the gas cap and disconnected the battery then I swapped the bad filter. Never had any problem since. </TD></TR></TABLE>
Thats how I change mine.
Agent Zero
Honda S2000
Mar 4, 2008 10:08 PM
jmaz
Honda Civic (2006 - 2015)
Aug 8, 2007 04:30 AM
sz9182
May 6, 2007 11:20 AM
tamashi523
Dec 14, 2005 05:28 AM
Rpizzle
Apr 7, 2005 09:37 AM
