changing fuel filter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20ls01 »</TD></TR><TR><TD CLASS="quote">
it is but this article says something about unplugging the fuel pump electrical connector
http://www.team-integra.net/se...D=391
cant i just unplug the battery?
I just changed my filter last month. I know the haynes says to disconnect the fuel pump connector under the rear seats. I didn't do that. All I did was release pressure from the gas cap and disconnected the battery then I swapped the bad filter. Never had any problem since.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by int3gra07 »</TD></TR><TR><TD CLASS="quote">
I just changed my filter last month. I know the haynes says to disconnect the fuel pump connector under the rear seats. I didn't do that. All I did was release pressure from the gas cap and disconnected the battery then I swapped the bad filter. Never had any problem since. </TD></TR></TABLE>
Thats how I change mine.
