over heating problem
Old Jun 7, 2007 | 07:41 PM
civic4g63's Avatar
Default over heating problem
My fan wont turn on so my car keeps over heating, I replaced the swtich on the thermo housing. does anybody know what else could it b?
Old Jun 7, 2007 | 08:01 PM
civic4g63's Avatar
Default Re: over heating problem (civic4g63)
anybody? lower radiator hose gets hot so i know it cant b the thermostat
Old Jun 7, 2007 | 08:05 PM
prodigee's Avatar
get a new fan? or radiator?
Old Jun 7, 2007 | 08:18 PM
civic4g63's Avatar
Default Re: (prodigee)
i jumped the fan to the battery 2 test it an it works fine, radiator is brand new
Old Jun 7, 2007 | 08:40 PM
dtapia's Avatar
Default Re: (civic4g63)
what model is it i will get you some info.
Old Jun 7, 2007 | 08:53 PM
dtapia's Avatar
Default Re: (dtapia)
ok here is some info ona 2000 civic
Fans
How the Circuit Works
Radiator Fan
Voltage is provided at all times to the radiator fan
relay (contacts) through fuse 57. With the ignition
switch in ON (II), voltage is provided to the coil of
the relay through fuse 17.
The radiator fan relay can be grounded through
either the engine coolant temperature switch or the
engine control module (ECM) or powertrain control
module (PCM).
The engine coolant temperature switch grounds
the radiator fan relay (coil) when the engine
coolant temperature exceeds 199F (83C). The
switch opens when coolant temperature
decreases 3– 8C.
Condenser Fan
Voltage is provided at all times to the condenser fan
relay (contacts) through fuse 56. With the ignition
the relay through fuse 17. When you push the A/C
switch and put the heater fan switch in 1, 2, 3, or 4
position, the A/C thermostat comes on, the
condenser fan relay energizes, and the condenser
fan motor runs.
A/C Thermostat
The A/C thermostat is located on the evaporator
housing. The A/C thermostat turns off the A/C
compressor clutch if the temperature at the
evaporator goes below 3C (37F). This prevents
condensation from freezing on the evaporator fins
and blocking the air delivery into the passenger
compartment. If the temperature goes below 3C
(37F) turning off the A/C thermostat, ground will be
removed from the condenser fan relay. This will
deenergize the relay and remove voltage from the
condenser fan motor causing the fan to stop running.
Refer to the Service Manual (Section 23, Electrical)
for specific tests or troubleshooting procedures.
Old Jun 7, 2007 | 09:15 PM
95ProjectEJ1's Avatar
Did you check the relay in your engine base fuse box?
Old Jun 8, 2007 | 07:23 AM
civic4g63's Avatar
Default Re: (95ProjectEJ1)
yea i bought a new relay it still dosent work and its a 98 honda civic ex
Old Jun 8, 2007 | 12:34 PM
ek4_b16a's Avatar
i once was told that the coolant fan switch sensor, even if bought brand new, could be defective...unless you have a break in that sensor's wiring...just a thought...gl...mines the same...still can't figure out what is wrong with the thing...just rigged a toggle switch on to turn it on and off whenever i want...
Old Jun 8, 2007 | 03:34 PM
civic4g63's Avatar
Default Re: (ek4_b16a)
Thanx not sure if its the ecu though,
Gonna try a different ecu and see if that's the problem
Old Jun 8, 2007 | 03:39 PM
byronl's Avatar
check the wiring, i had a wire that was cut that made the fan didn't turn on for the thermoswitch.
Old Jun 8, 2007 | 03:44 PM
smokerz212's Avatar
use jumper to try if the fun is really working... and if yes, look for the wires specially on the connectors...
Old Jun 9, 2007 | 09:00 AM
civic4g63's Avatar
Default Re: over heating problem (smokerz212)
ill check the wiring tonight but last time i checked it was ok all the connections was fine and pluged in, i jumped the fan to the battery and the fan turns on, the car has a new radiator, thermo swtich, thermostat works fine, radiator fan works, new relay, i think i am going to check the wiring an fues 1 more time
Old Jun 10, 2007 | 10:30 AM
civic4g63's Avatar
wiring is fine dont know what else could it b
Old Jun 10, 2007 | 11:24 AM
dtapia's Avatar
ok here is a diagram of a 2000 civic since you failed to give more info on year since they are diffrent from gen to gen
Old Jun 11, 2007 | 07:26 AM
civic4g63's Avatar
Default Re: over heating problem (dtapia)
ttt i turned my ac fan the radiator fan doesnt come on, i was told that they were suppsed to both come on when i turn the ac, but the radiator fan doesnt come on so iam thinkin it has to b the relay
Old Jun 11, 2007 | 07:54 AM
1.6vx's Avatar
have you check the censor that sits on top of your thermostat ? I went trough the same crap you did and that was my problem. good luck.
Old Jun 11, 2007 | 08:20 AM
civic4g63's Avatar
Default Re: (1.6vx)
sensor is brand new
Old Jun 11, 2007 | 09:14 AM
ziptie's Avatar
damn gl
Old Jun 11, 2007 | 09:41 AM
civic4g63's Avatar
Default Re: (jagoff)
thanx
redbull99
Aug 27, 2015 10:19 AM
asoRm
Aug 13, 2014 12:10 PM
EK9JSPEC
Aug 27, 2012 09:11 PM
JH4DB858
Jan 10, 2012 07:32 PM
esean93
11
Jul 29, 2008 05:33 PM
