GSR REAR DISC CONVERSION???
i just got my rear disc conversion done....does it suppose to affect your alignment??? it pulls to the left.... i know its a silly question but i wonder if it affects the alignment or not or i did it wrong...thanks guys
anytime you mess with your suspension like that you should get an alignment, that should fix your problem. also did you use your civic lower control arms because you were supposed to, the integras are longer and will cause severe negative camber
He probably have a 92-95 civic, not a 96-00 civic. So the control arm shouldn't be a problem, since the 92-95 civic one is interchangable with 93-whatever integra.
fraknstien
May 12, 2006 04:08 PM
eghatchproject
Mar 16, 2004 07:05 AM
