dang! my ek died tonight. auto motor needed IL/WI/MI/IW/ Midwest?
Old Jun 7, 2007 | 06:57 PM
43!'s Avatar
43!
Default dang! my ek died tonight. auto motor needed IL/WI/MI/IW/ Midwest?
I need a motor asap to get to work. fuch.
Please pm me. cash in hand.
Old Jun 7, 2007 | 07:26 PM
Jhonny Ricer's Avatar
Default Re: dang! my ek died tonight. auto motor needed IL/WI/MI/IW/ Midwest? (43!)
Did you try classifieds? What happened to your motor?
Old Jun 7, 2007 | 07:35 PM
43!'s Avatar
43!
Default Re: dang! my ek died tonight. auto motor needed IL/WI/MI/IW/ Midwest? (Jhonny Ricer)
i cleaned the engine bay good with some degreaser i got at autozone. wiped off the excess water/moisture and slammed the hood to let her dry. came back out after about ten minutes and it wasn't running. I tried to restart and it barely idles with my foot on the gas. its fucked, i should have left it dirty. =/
i have been having overheating issues lately as well. i guess it was a matter of time.
she was my 100+ miles a day ride to work. i'm screwed.
Old Jun 7, 2007 | 07:55 PM
ridin98civic's Avatar
i dont think you killed your engine with water and degreaser unless you were spraying it in your intake.
Old Jun 7, 2007 | 08:22 PM
43!'s Avatar
43!
Default Re: dang! my ek died tonight. auto motor needed IL/WI/MI/IW/ Midwest? (ridin98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic &raquo;</TD></TR><TR><TD CLASS="quote">i dont think you killed your engine with water and degreaser unless you were spraying it in your intake.</TD></TR></TABLE>
It's running so rough now though. I'm going to try again in the AM =/
Old Jun 7, 2007 | 09:12 PM
check to see if there is water in the spark plug tubes, check your plugs, check your cap and rotor (i have seen water in a dist. cap), was it running while you were washing it?
Old Jun 7, 2007 | 10:01 PM
gtlaw1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic &raquo;</TD></TR><TR><TD CLASS="quote">check to see if there is water in the spark plug tubes, check your plugs, check your cap and rotor (i have seen water in a dist. cap), was it running while you were washing it?</TD></TR></TABLE>
once it drys it will be ok
I can't believe you would be capable of replacing the motor if you think getting the **** wet then it running like crap means you need a new motor
aeon
Jul 20, 2008 10:14 AM
e30slut
May 30, 2008 08:48 PM
lduque
Jul 12, 2007 08:09 AM
fitbmx86
May 13, 2007 10:10 AM
iBrandon
Nov 29, 2006 09:40 PM
