Failed California smog test. Need your help..
Old Jun 7, 2007 | 06:57 PM
jdminspiredDB8's Avatar
Default Failed California smog test. Need your help..
1995 Integra GSR
131k Miles
Car is bone Stock with only a AEM CAI, and APEXi WS Exhaust.
Someone please help me, so I can make it pass, I would appreciate any help, thanks.
Here are the results:
Old Jun 7, 2007 | 07:22 PM
Red4drLSintegra's Avatar
check this website:
http://www.smogcheck.ca.gov
wheres the top half that explains what passed and what failed? that may help
Old Jun 7, 2007 | 07:30 PM
fergy016's Avatar
Default Re: (Red4drLSintegra)
Nitrogen
The things to check are...
Check the timing on the car. If it is too far advanced it can cause to much NOX.
Have you replaced your spark plugs recently? probably not.
Is your catalytic converter stock? I bet it is, looks like time to replace it (not a high flow one!!)
Were you running 87 octane fuel?
Old Jun 7, 2007 | 07:39 PM
Default Re: (fergy016)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fergy016 &raquo;</TD></TR><TR><TD CLASS="quote">Nitrogen
Yea I replaced the spark plugs recently. I replaced my cat about 2 yrs ago on my last smog. Im running 91 octane
Old Jun 7, 2007 | 07:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red4drLSintegra &raquo;</TD></TR><TR><TD CLASS="quote">check this website:
wheres the top half that explains what passed and what failed? that may help</TD></TR></TABLE>
the top half is the visual, I passed all of them
Old Jun 7, 2007 | 07:45 PM
doood's Avatar
been there done that
Default Re: (jdminspiredDB8)
do a tune up. oil, filter, etc.
a simple oil, filter, and plug change helped my i/h/e b18c1 pass.
Old Jun 7, 2007 | 07:46 PM
the top part above the results usually tells you what you passed and what failed.. its a list of items..
im thinkin it could be something with your timing.
Old Jun 7, 2007 | 07:52 PM
dc2long's Avatar
since your car is a 95. take it to acura and have them fix it. FREE EXTENDED WARRANTY (emission service) for vehicles 95-97 with mileage under 150k. if your check engine light is on then take it to them and if the code is for your cat, then they will replace it for FREE.
*look it up before going there. im not sure about all the rules
Old Jun 7, 2007 | 09:48 PM
Default Re: (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">do a tune up. oil, filter, etc.
a simple oil, filter, and plug change helped my i/h/e b18c1 pass.</TD></TR></TABLE>
i've done that already.
Old Jun 7, 2007 | 10:29 PM
Rice-aronie's Avatar
Did u drive enough for the cat to warm up? That can help, also Heet is supposed to help with smog. Run octane booster the next time you take it back too.
Old Jun 7, 2007 | 10:32 PM
iaintnogangster's Avatar
Default Re: Failed California smog test. Need your help.. (jdminspiredDB8)
wutsup chris....my car didnt pass smog and the numbers kind of looked like that....the only thing thats different is my car also failed the HC part....i changed my cat and i passed with flying colors...
Old Jun 7, 2007 | 11:10 PM
Lauj87's Avatar
sometimes it could be something as small as a bad PCV valve.
Old Jun 7, 2007 | 11:41 PM
Default Re: (Rice-aronie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rice-aronie &raquo;</TD></TR><TR><TD CLASS="quote">Did u drive enough for the cat to warm up? That can help, also Heet is supposed to help with smog. Run octane booster the next time you take it back too. </TD></TR></TABLE>
Yup I drove it for about 30 min before smogging it.
Old Jun 7, 2007 | 11:42 PM
Default Re: Failed California smog test. Need your help.. (iaintnogangster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iaintnogangster &raquo;</TD></TR><TR><TD CLASS="quote">wutsup chris....my car didnt pass smog and the numbers kind of looked like that....the only thing thats different is my car also failed the HC part....i changed my cat and i passed with flying colors...</TD></TR></TABLE>
what were the numbers on the NOx???
Old Jun 8, 2007 | 01:09 AM
da4sale's Avatar
might as well get a funny smog and save your time likes hundreds of other tuners
Old Jun 8, 2007 | 06:50 AM
my NO numbers were 1485 on top and 1251 on the bottom when i was failing....
Old Jun 8, 2007 | 09:40 AM
fergy016's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iaintnogangster &raquo;</TD></TR><TR><TD CLASS="quote">my NO numbers were 1485 on top and 1251 on the bottom when i was failing....</TD></TR></TABLE>
what did you do to fix it?
Old Jun 8, 2007 | 04:41 PM
Default Re: Failed California smog test. Need your help.. (fergy016)
Ok I finally passed!!!! I replaced my cat and o2 sensor and passed with flying colors.
integra1990ls
Sep 23, 2008 08:32 AM
bigb0i88
Dec 13, 2007 09:37 AM
oneforce
Mar 7, 2006 07:37 AM
newludedude
Aug 22, 2004 12:12 PM
GSRaCeRbOI
Oct 23, 2002 12:18 PM
