Spoiler questions.
Do all the spoilers mount in the same location?
How many holes are on each side? Is the ITR spoiler different?
and
Do the spoilers have threaded rod coming out of them, or do you thread bolts into them?
Thanks ahead of time.
and
Yes, they all mount in the same place...
There are a total of 4 holes (2 on each side), on the passenger side, the hole is a little bigger for the light cable...
The thread is on the spoiler itself...
WINGLESS= CLEAN/SLEEK...
ITR wings only have 2 bolts on each side opposed to the stock spoiler which has 3 bolts on each side. The wing will bolt up, but you'll need to plug the remaining hole. Some replicas have 3 bolts on each side to cover the remaining hole, so if you're okay with a non-authentic product, that's also an option.
I bought an authentic ITR wing off of ebay. The pictures showed underneath two threaded rods and two holes.
I was checking here to see if that was correct or if there was something addtional needed.
Just a quick question, from what i heard you would have to redrill the holes to put in the ITR wing if you already have the stock Holes for the stock wing. I, myself haven't seen the bottoms of the ITR wings, but whole just a thought if it's true.
You don't need to drill holes if you had the stock wing.
https://honda-tech.com/zerothread?id=1562195
https://honda-tech.com/zerothread?id=1970436
Here are a couple threads about it.
Eg_TypeR
Paint and Body
Feb 25, 2008 05:22 PM
