CEL code 7 and 2
Old Jun 7, 2007 | 04:42 PM
Eli Mac 67's Avatar
Default CEL code 7 and 2
got code 7 and 2
7=Throttle Position (TP sensor)
2=O2B - Oxygen sensor #2
got a new O2 sensor orded but would code 7 be comein on because of the 02? the car idles up after start, it will start idle smoths out then a few seconds later the check engine light comes on and it idles up about 500rpm(up to almost 2grand)
is that cause its tryin to get more air to the 02 sensor??
If the tp sensor has nothin to go with the other code how would i go about fixing/finding out whats wrong there?
i check with a volt meter and the wire goin to the tp sensor has 5.4v goin to it...is that good or bad?
Old Jun 7, 2007 | 05:50 PM
Eli Mac 67's Avatar
Default Re: CEL code 7 and 2 (Eli Mac 67)
not 100% on how to change the volts goin to the tps...tryed puttin the meter on the wires i get a 5.4v reading then when i move the throttle from idle to WOT thing happins guessing need new sensor? or am i doin it wrong
Old Jun 8, 2007 | 02:30 PM
Eli Mac 67's Avatar
anyone
RiTtEk401
Oct 4, 2011 02:52 AM
hatchedzex
May 24, 2004 05:12 PM
BAZ
Apr 26, 2004 01:45 PM
IVI
Mar 25, 2004 07:27 AM
12 oz.
Jun 3, 2002 04:05 PM
