H22a overheat on highway
I recently took a two hour trip from jersey to PA and after a while i noticed that my heat gauge was all the way in the red. What could i do to prevent this from happening in the future?
Last and hopefully least.......check your head gasket. My lude did the same and lost coolant about a cup a week. Turns out head gasket was leaking into cyl#3. Truly hope this is not your case!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECX »</TD></TR><TR><TD CLASS="quote">t-stat?
I'm looking to learn something out of this one as well (as you can see
)</TD></TR></TABLE>
hmm...when the t-stat is badm usually the temp only goes up at idle. Going dow the highway, he should have been fine.
)</TD></TR></TABLE>hmm...when the t-stat is badm usually the temp only goes up at idle. Going dow the highway, he should have been fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .BigSexy »</TD></TR><TR><TD CLASS="quote">
hmm...when the t-stat is badm usually the temp only goes up at idle. Going dow the highway, he should have been fine. </TD></TR></TABLE>
I'm not sure I understand that logic. If the thermostat was stuck closed, the problem would be worse on the highways as your engine is running faster generating more heat than at idle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nyluder »</TD></TR><TR><TD CLASS="quote">If it happend on the highway try to pull over and change the thermostat.</TD></TR></TABLE>
and then go to the emergency room and get those 3rd degree burns taken care of.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95PreludeSi »</TD></TR><TR><TD CLASS="quote">
and then go to the emergency room and get those 3rd degree burns taken care of.</TD></TR></TABLE>
LMFAO, SAME THING I WAS THINKING!!!!!
ragge_c
Dec 23, 2003 11:40 AM
