Car stutters and misses after replacing coil. Ideas?
Old Jun 7, 2007 | 10:13 AM
Mr. Self Destruct's Avatar
Default Car stutters and misses after replacing coil. Ideas?
Tried to search on this, but didn't find anything....
I was driving down the road ~45 MPH, and the car stutters violently for about a 1/4 of a second and then dies. I pull over and try to start it back up, but get nothing. I check for fuel and make sure there are no timing belt issues. Everything checks out, so I figure it's an ignition problem. My first instict is that it's the coil, so I check it with an Ohm-meter, and find that the reading between the positive terminal and the coil spring is open (supposed to be between 12.8 and 19.2 Ohms), so the coil is definitely dead.
I buy a new rotor, cap, and coil from Advance. I put the parts on the car, and now it starts up and idles fine.... UNTIL I drive it. When I take it out to drive, it runs perfect for about 30 seconds (or until it warms up maybe?), then it starts stuttering/missing pretty heavily on acceleration. After driving it, when I pull it back into the garage, it will continue to miss at idle until I shut it off. If I let the car sit for a while and cool down, the missing will go away upon start up, until it warms up again....
I'm about to go pick up some new spark plugs and wires, but I doubt that's the problem...
The car is a '95 Integra RS. Vehicle ran absolutey perfectly before the coil went bad. NO problems. The car is completely, 100% stock.
Anoyone have any ideas as to what the problem could be???? I'm stumped...
Old Jun 7, 2007 | 10:24 AM
egsleepercivic's Avatar
possibly the ICM
Old Jun 7, 2007 | 10:47 AM
Default Re: (egsleepercivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">possibly the ICM </TD></TR></TABLE>
Oh, really? I thought if the ICM went out, the car wouldn't run at all.... Good to know. I think I have a spare dizzy with an ICM in it. I'll swap them out and report back.
Old Jun 7, 2007 | 04:34 PM
Default Re: (Mr. Self Destruct)
Replacing the ICM did the trick. Runs perfect now.
Old Jun 7, 2007 | 07:39 PM
good stuff, the old coil may still be good
Old Jun 8, 2007 | 03:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">good stuff, the old coil may still be good</TD></TR></TABLE>
That's the weird thing.... The coil is definitely bad too. It tested bad, and the car won't even start with it. What are the chances of the coil and the ICM going out at the same exact time????
Old Jun 8, 2007 | 06:38 AM
I had coil go out and had it replaced at the dealer before my swap and they said the icm goes a lot of times when the coil goes, idk if the were BS'n me or what but i had it replaced also
Old Jun 29, 2009 | 01:40 AM
Integra4lyfe069's Avatar
Default Re: Car stutters and misses after replacing coil. Ideas?
ICM means ?
Old Jun 29, 2009 | 05:32 AM
fcm's Avatar
fcm
Old Fart
ICM = ignition control module. 94
Old Jun 29, 2009 | 08:37 AM
srmofo's Avatar
sometimes when coils go bad they damage other components near by. The secondary ignition voltage has got to go somewhere and sometimes it goes straight into the ignitor. its not that unusual considering they almost touch. Those things are finicky anyways and a small voltage spike usually burns them up.
slikz714
Apr 27, 2009 03:18 AM
95blackEG
Dec 24, 2008 07:59 PM
JoHA
Jun 9, 2008 07:50 AM
angie1977
Oct 4, 2006 07:19 AM
dvp95
Aug 20, 2003 11:10 AM
