need to make right choice, any ideas?
Old Jun 7, 2007 | 09:11 AM
motor_man's Avatar
Default need to make right choice, any ideas? ekforeverguy, anyone?
alright i just got a 98 dx coupe a few weeks ago and i cant decide on wat i want to do to it, its just a daily i have a mint si crx that im going to build the motor from the ground up thats my dream car (im going to leave the bodie stock except for rims and tint). but for the dx i dont kno if i want to turbo the stock d16y7 motor or get motor swap, the car now has some kind of after market headers 4-2-1 it has a real aem cold air, it might have a stage two cam not sure havent checked it, it has a aem cam gear and a horrible magnaflo exshust. i just want a fast daily that i can beat the average integra/ prelude, and the infamus mustang gt/ 5.0. i have a $3,500 budget not a cent more and after that im finished with that car except for general upkeep. any ANY suggestions would be greatly apreciated im open to anything in my budget. thanks
Modified by motor_man at 9:20 PM 6/7/2007
Old Jun 7, 2007 | 09:21 AM
Racing rice's Avatar
New User
A Turbo kit on the D16 will get you want just be sure to factor in Tuning into the overall cost. It would be a waste to do that work, and blow up the motor.
The swap is always a viable option as long as you can source a motor and stay within your budget. Don't forget to factor in the small things, mounts, etc.
With enough research and hunting you maybe able to piece together both if you take your time and look around.
Old Jun 7, 2007 | 09:24 AM
motor_man's Avatar
Default Re: (Racing rice)
well besides for tuning the turbo. but it wouldent be a big turbo im talkin about small boost, so u dont think the stock motor could handle boost?
Old Jun 7, 2007 | 09:29 AM
New User
Default Re: (motor_man)
That depends on many factors. The current condition on the motor especially. You should always have the current motor checked out before even attempting an install. You may find that it needs more work then you think. A stock engine in good condition can handle a small amount of boost on stock internals without a problem aslong as it's tuned properly (A/F ratios, etc.) Not to mention, dyno time will optimize your power safely. After all, isn't that what it's all about? Getting the most out of the engine without spending a fortune in the process. Sometimes dyno tuning can net you more gains then the actual install itself. Especially in the long run.
Old Jun 7, 2007 | 09:36 AM
motor_man's Avatar
yea thats wat its all about but from wat ive heard getting a car on a dyno can cost a pretty penny plus im still not sure wat i want but im getting the car checked out thanks to my lady and even without that the cars in great shape and purs like a kittn and threres records showing oil changes, and full tune ups but ill kno once i get it checked.
Old Jun 7, 2007 | 09:56 AM
New User
Getting it checked out is always a good place to start. You'll find out real quick if it's even worth putting money into. It can make your decision a lot more easy. Yes, dyno time can be expensive. Thats why I mentioned it. It can cost as much as a few hundred an hour. Some clubs/groups have dyno days which they can get dyno tuning done cheaper then usual. Some places around here do it for like $100 an hour on such days.. Just make sure it's a fairly reputable company.
Old Jun 7, 2007 | 10:20 AM
motor_man's Avatar
alright yea ill look into it thanks but just for kicks if IF i do decide to turbo how much psi do u think the d16y7 can handle
Old Jun 7, 2007 | 10:30 AM
motor_man's Avatar
Default Re: need to make right choice, any ideas? (motor_man)
ok well i have a job site i have to visit, if any one has any comments/suggestions/or ideas please reply PLEASE.
Old Jun 7, 2007 | 10:50 AM
New User
You can usually get about 8psi on stock internals with a good tune and proper parts kit. More importantly, you should be able to get about 200Hp on the stock internals. Maybe more if everything is spot on..
Modified by Racing rice at 8:01 PM 6/7/2007
Old Jun 7, 2007 | 12:21 PM
VTECth1s's Avatar
Default Re: need to make right choice, any ideas? (Racing rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racing rice &raquo;</TD></TR><TR><TD CLASS="quote">You can usually get about 8psi on stock internals with a good tune and proper parts kit. More importantly, you should be able to get about 200Hp on the stock internals. Maybe more if everything is spot on..
Well it depends on the turbo the OP is using that will make his car reach 200+ whp. The OP could do a rebuild for a boosted application, doing a compression and leak down test to see what needs to be replaced, then source a custom turbo kit or a bolt-on turbo kit from greddy, revhard, etc. Along with supporting mods with that turbo setup, then have it tuned which is most crucial of all. Turbo'd d-series is more in your budget, if you don't want to swap out a new motor like a b-series then doing turbo on it.
Old Jun 7, 2007 | 07:42 PM
motor-honda_p's Avatar
bump
Old Jun 7, 2007 | 08:08 PM
Default Re: (srehtorblos)
well the money im using for the dx was mostly givin to me from my girl and i want a fast daily so the set amount is wat i have for that car plus she wants it to go faster and shes sayin turbo it in my ear all the time so i said pay for it and ill think of somthing &lt;i made this profile cause i only have 5 post a day and i need to think of sumthing fast or else she wont pay for it&gt;
Old Jun 7, 2007 | 08:27 PM
Default Re: need to make right choice, any ideas? ekforeverguy, anyone? (motor_man)
bump / ek forever guy/ anyone?
Old Jun 7, 2007 | 09:32 PM
ridin98civic's Avatar
Default Re: need to make right choice, any ideas? ekforeverguy, anyone? (motor-honda_p)
get the motor tested to make sure its healthy, then boost it. im shooting for a 200+ whp d16y8 for under 2000 right now.
Old Jun 7, 2007 | 09:38 PM
Default Re: need to make right choice, any ideas? ekforeverguy, anyone? (ridin98civic)
well had it looked at all day today guy said it was good but left there for more tests. wat psi are u running?
Old Jun 7, 2007 | 09:41 PM
its really not about what psi more what you have as a power goal. however i will be shooting for 200+ at not more than 10 psi.
theres my thread, if you need some ideas
https://honda-tech.com/zerothread?id=1982900
Old Jun 7, 2007 | 09:45 PM
gtlaw1's Avatar
Default Re: (motor-honda_p)
your probably better off getting a better car for a fast reliable DD.. I just made the mistake of getting a DX because I never thought I could get an EK so cheap, but in retrospect I wouldn't have wasted my time the car doesn't even have swaybars! if you really want an awesome DD and have $3500 to spend making it quick just sell the DX and get a 91-94 sentra se-r you'll spend a ton of money trying to make your honda as good as these are
Old Jun 7, 2007 | 09:46 PM
alright thanks man my goal is to to get about 200whp if i do boost but i dont want to get to much boost and blow the motor up but yea thanks
Old Jun 7, 2007 | 09:53 PM
Default Re: (gtlaw1)
91-94 se-r
Engine Code: SR20DE
Horse Power: 140 @ 6400rpm
Torque: 132 lb/ft @ 4800rpm
RPM limited at 7500rpm (200SX SE-R is limited to 7100rpm)
Displacement: 1998cc
Compression: 9.5:1
0-60mph: approx. 7.6 to 8.3 seconds
1/4mile: approx. 15.8 seconds
yea thats real fast
boosted d
Old Jun 8, 2007 | 10:28 AM
gtlaw1's Avatar
Default Re: (ridin98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic &raquo;</TD></TR><TR><TD CLASS="quote">91-94 se-r
Engine Code: SR20DE
Compression: 9.5:1
yea thats real fast
boosted d </TD></TR></TABLE>
but it has a lsd, front and rear swaybars, and an engine with strong internals that will handle more power than any stock honda setup.just look at what you'll spend making a dx equal it. besides for a quick DD its faster, and better than a stock gsr or ek si
Old Jun 8, 2007 | 10:30 AM
Libertariat's Avatar
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtlaw1 &raquo;</TD></TR><TR><TD CLASS="quote">
but it has a lsd, front and rear swaybars, and an engine with strong internals that will handle more power than any stock honda setup.just look at what you'll spend making a dx equal it. besides for a quick DD its faster, and better than a stock gsr or ek si</TD></TR></TABLE>
"Welcome to H-T, Please check all SR20's, 5.0's, SRT-4, VW's, at the door. You may pick them up when you leave."
Old Jun 8, 2007 | 10:35 AM
gtlaw1's Avatar
Default Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">
"Welcome to H-T, Please check all SR20's, 5.0's, SRT-4, VW's, at the door. You may pick them up when you leave."</TD></TR></TABLE>
forgot to mention it also has rear discs
I would love to swap my sr20 out of my rusty se-r and into my shiny new honda, but there would be a problem with getting emissions testing since the honda is obd 2, axles would also be a real pain
Old Jun 8, 2007 | 10:43 AM
Ek Forever y0!
If I had $3500 I'd get an LS with a gsr/b16 tranny and turbo it.
You'd even have money left over for aesthetics/suspension.
There's several things you could do, you could even budget an h2b with $3500 and put your civic in the 12's.
OR build your d and boost it.
Too many things to do, $3500 has potential.
Old Jun 8, 2007 | 10:49 AM
jblunt's Avatar
with 3,500 i would do a motor swap
Old Jun 8, 2007 | 11:46 AM
motor_man's Avatar
well thank u every one. today i purchased a wrecked si vtech del sol for $500, im going to swap the motor my self i have vtech controls and everything i need plus mounts to mod and with the money left over im going to tune and boost hopefuly every thing works and soon ill be working on my crx and i will probaly need help with that knowing my luck! and again thank you if u guys want progress pics in such ill be posting the motor swap and i might have questions that need to be answered.
