Grinds into third
Old Jun 7, 2007 | 07:19 AM
Han Solo's Avatar
Default Grinds into third
My car (1995 Honda del Sol VTEC(b16)). Grinds into third if i shift above 5,000rpm. It happens ONLY at downshifting or upshifting above 5,000. Any ideas?
Old Jun 7, 2007 | 07:29 AM
Han Solo's Avatar
Default Re: Grinds into third (VTECommie)
Im going to try syncromesh and maybe change out the fluid. The funny thing is, this only started AFTER i reinstalled the linkage, could there be a problem there?
Old Jun 7, 2007 | 08:47 AM
ICC_Texas's Avatar
If the linkage is left in alone for quite some time (factory) or just driven a lot in a certain spot, it wears the gears a certain way.
Once the angle or force is changed ever-so-slightly, the variables that were once true are now different.
Check your shifter bushing to ensure its not totally wore out and everything is at it should. If all that checks out, replace your tranny fluid and that will give you a band aid for your current issues.
Old Jun 7, 2007 | 08:57 AM
sauceja's Avatar
Default Re: (ICC_Texas)
Welcome to the B-series tranny 3rd gear grind club.
Your synchros have worn over time. If left alone it will eventually start eating at your dog teeth and then totally screw up 3rd gear.
Then you will have to buy the 3rd/4th gear set to replace third gear.
My advice would be to open her up and replace the synchro. GM syncromesh is like closing your eyes and ears while your sister is getting raped in front of you.
Old Jun 7, 2007 | 08:58 AM
Probot's Avatar
try changing the tranny fluid and MAKE SURE you use Honda Manual Trans Fluid..had the same problem --- changed the fluid car shifted smooth as could be, but yea, make sure you use the honda brand trans fluid
Old Jun 7, 2007 | 08:53 PM
Han Solo's Avatar
Default Re: (Probot)
but, it just happened after i reninstalled the shift linkage, could there be something i installed incorrectly? im changing fluid/syncromesh tomorrow. whats a good proportion 2 quarts to .5 quarts?
Old Jun 7, 2007 | 09:15 PM
smileycvc's Avatar
Default Re: (VTECommie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Probot &raquo;</TD></TR><TR><TD CLASS="quote">try changing the tranny fluid and MAKE SURE you use Honda Manual Trans Fluid..had the same problem --- changed the fluid car shifted smooth as could be, but yea, make sure you use the honda brand trans fluid</TD></TR></TABLE>
whats wrong with syncromesh?
Just fill the whole thing up with syncromesh. I had the same problem so I started using amoil manual syncromesh fluid.
Old Jun 7, 2007 | 10:58 PM
nvynuke18's Avatar
Default Re: (smileycvc)
AMSOIL is the ****!!!
Old Jun 7, 2007 | 11:12 PM
smileycvc's Avatar
Default Re: (nvynuke18)
yeah amsoil i missed the s sorry
Old Jun 8, 2007 | 07:24 AM
Han Solo's Avatar
Well I already have Honda MTF fluid right now, so Im just going to use the GM syncromesh as an additive.
Old Jun 8, 2007 | 08:14 AM
crazyguy's Avatar
grinds in 3 is normal due to normal wear and tear.
it happened to me once too.i ended up replacing the whole newer tranny.
cheaper that way.i got a newer tranny for under 100 bucks.
but i was talking about on a d series tranny..
on your b series.it will cost a lot more to buy
and now it shifts fine and pulls hard
Old Jun 8, 2007 | 10:05 AM
smileycvc's Avatar
Default Re: Grinds into third (crazyguy)
yeah if you can find a b16 tranny for 100 bucks that works well, then it probally glows its so hot.
Nate13
24
Jul 9, 2010 08:19 AM
rizq777
Sep 25, 2004 07:57 AM
Luchini
Jan 13, 2004 12:32 AM
elevatethis
41
Nov 24, 2003 12:02 AM
3rdGteg
May 7, 2002 10:23 PM
