wierd tranny problem?
Old Jun 6, 2007 | 07:59 PM
error's Avatar
Default wierd tranny problem?
so after some hard driving my car wouldnt go into gear/move in any gears. i assumed my clutch went out. so after spending all day putting a new clutch in, i still have the same problem; MY CAR WONT BUDGE!
i didnt replace or resurface the flywheel because it looked decent.
it makes a a slight whine when i put it into reverse but thats it.
WTF is wrong with my car; 94 LS
Old Jun 7, 2007 | 04:30 AM
error's Avatar
Default Re: wierd tranny problem? (error)
any one?
Old Jun 7, 2007 | 05:22 AM
ndogg's Avatar
it wont go into gear? or when you put it in gear nothing happens?
Old Jun 8, 2007 | 04:21 AM
error's Avatar
Default Re: wierd tranny problem? (ndogg)
nothing happens.
im going to check over the axels when i get home from work.
Old Jun 9, 2007 | 07:14 AM
error's Avatar
******* axles
Old Jun 9, 2007 | 09:36 AM
b18c1ej8's Avatar
slave cylinder?
Old Jun 9, 2007 | 10:25 AM
solerizr's Avatar
Default Re: wierd tranny problem? (b18c1ej8)
You changed your clutch and didnt see that the axles were messed up?
Old Jun 9, 2007 | 12:41 PM
error's Avatar
Default Re: wierd tranny problem? (solerizr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solerizr &raquo;</TD></TR><TR><TD CLASS="quote">You changed your clutch and didnt see that the axles were messed up?</TD></TR></TABLE>
the axle was messed up inside of the boot so i couldnt really tell. it wasnt as obvious as a broken axle shaft.
Old Jun 9, 2007 | 05:21 PM
hitekper4mance's Avatar
How did you realize it was the axle? Did the whole axle not spin?? I'm only asking because I have a similar issue and I dont want to tear the tranny up. Mine is doing the same thing, but, when I jack up the car, I spin the wheel and it looks like the entire axle is spinning. not just a part of it (as if it were broken inside the joints or something). I dont want to replace the axles either if its the differential. So, I am just trying to make sure I take it on head first. Obviously, you know what a bitch it is when you fix something that isnt even broken. THanks.
Old Jun 10, 2007 | 06:41 AM
error's Avatar
Default Re: wierd tranny problem? (hitekper4mance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hitekper4mance &raquo;</TD></TR><TR><TD CLASS="quote">How did you realize it was the axle? Did the whole axle not spin?? I'm only asking because I have a similar issue and I dont want to tear the tranny up. Mine is doing the same thing, but, when I jack up the car, I spin the wheel and it looks like the entire axle is spinning. not just a part of it (as if it were broken inside the joints or something). I dont want to replace the axles either if its the differential. So, I am just trying to make sure I take it on head first. Obviously, you know what a bitch it is when you fix something that isnt even broken. THanks. </TD></TR></TABLE>
i jacked up the car and let it idle in fifth gear. the passenger side axle spun up to the boot near the wheel, which did not turn. when i let it idle in first everything appeared to work but i knew it wasnt right. try stoping the tires from spinning and observe if the axles continue turning. or do what i did and idle it in fifth. im sure you will figure out a way to diagnose it. hope that helps .....
oh yeah and if your car doesnt run, just turn from the crank pully with a socket with it in gear. harder tho.
yc_dc4mar
Transmission & Drivetrain
14
Aug 28, 2008 11:36 PM
c0l7hy
May 16, 2008 08:35 PM
veilsides2000
Jan 15, 2006 08:51 PM
vtec69
Mar 28, 2003 09:15 PM
tooqwik1
Jul 14, 2002 03:26 AM
