gsr swap into my da integra serious help!!!!!!
Old Jun 6, 2007 | 07:16 PM
unrivaledintegra's Avatar
Default gsr swap into my da integra serious help!!!!!!
i need to no if i could use my ls wiring harness with my b18c and if so,,, how could i run vtec senors and wat senor can i stock or if any has a obd1 gsr wiring harness for sale i am very interested
Old Jun 8, 2007 | 08:39 AM
b18c1ej8's Avatar
Default Re: gsr swap into my da integra serious help!!!!!! (unrivaledintegra)
the most logcial thing u should do would be to find an obd0 b16 harness becuz its obviously already wired for vtec
Old Jun 8, 2007 | 03:41 PM
GSR-TRBO-DA's Avatar
WHAT YEAR IS YOUR DA IF ITS 90-91 ITS OBDO IF ITS 92-93 ITS OBD1 IM INSTALLING A 97 GSR IN MY 92 DA AND USING THE FACTORY ( LS) HARNESS AND IM JUST GOING TO WIRE MY VTEC AFTER I INSTALL IT.
Old Jun 8, 2007 | 09:02 PM
Default Re: gsr swap into my da integra serious help!!!!!! (GSR-TRBO-DA)
ya but i sold my ls motor with everything else and i have to get a harness bcuz they sent me one all cut up and they won't send me another one and i found one harness but that is the one for the engine alone i need the one that hooks in the e.c.u.
Old Jun 8, 2007 | 09:47 PM
1DA2NV's Avatar
Default Re: gsr swap into my da integra serious help!!!!!! (b18c1ej8)
that is the same thing i did when i swapped in my B16A3, i just used my existing harness and ran the 3 Vtec wires after, it was that easy
Old Jun 8, 2007 | 09:50 PM
ABCVTEC's Avatar
Default Re: gsr swap into my da integra serious help!!!!!! (1DA2NV)
Just swap it in and use any B18 harness you can find. If it's a B18A/B harness you will need to run three wires for VTEC and another to the knock sensor.
I recommend you check out this link for further help:
http://www.g2ic.com/tegtips/en...e.doc
It has every possible swap into both series of DAs with what you need and what you need to do.
Old Jun 9, 2007 | 12:37 PM
Default Re: gsr swap into my da integra serious help!!!!!! (ABCVTEC)
thanks bro thats some help there but also along with any b-series harness can it be odb0, odb1,or 0bd2
toolbox21
Jun 12, 2012 09:50 AM
anzh86
15
May 19, 2011 08:50 AM
crazy-teggy-ls
May 5, 2009 08:20 AM
B18CYAAA
Jul 16, 2007 03:59 PM
nvmyb20hatch
Nov 30, 2005 12:02 AM
