P28 ECU is better for B16 engien instaed of E30 ECU?
a guy told me a p28 ecu is better for a b16 engine instead
of its orignal equipped p30 ecu?
does that mean i have to get e28 ecu chipped or ??
whats your opinion??thanks
The p28 will need to be chipped as it's an ecu for a sohc motor.
It will make any dohc motor run poorly.
The p28 is a popular choice for tuning.
If you want to use a SOHC ECU like the P28 to run a DOHC engine like a B16 then yes you will need to have it chipped.
If your car is the same OBD as the ecu then a P30 will be fine. Make sure you have a knock sensor because the P30 will look for one as the P28 will not look for a KS.
I run a chipped P28. The beauty is a chipped ecu can run a B16, B18A/B/C, B20, LSVTEC, CRVTEC, H22, F22, H2B.......................
Except with IAB Intake manifolds but I think there are plug-ins if you run crome/crome pro.
ya i had a p28 on my b16a and vtec popped at 5 and rev limiter at 7400. it was a dog. then i swapped in my p30 and now im getting vtec at 58 and rev limiter at 8500. even though now i am getting a knock sensor code
Damnit you beat me.
A chipped ecu can be set to have vtec and rev limit and governer whereever you want them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGLUVN »</TD></TR><TR><TD CLASS="quote">ya i had a p28 on my b16a and vtec popped at 5 and rev limiter at 7400. it was a dog.</TD></TR></TABLE>
You obviously didn't get it chipped/tuned.
What did you think a sohc ecu was going to do on a dohc engine?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">What did you think a sohc ecu was going to do on a dohc engine?</TD></TR></TABLE>
Its like the fat kid in gym class.
i didnt put the p28 in because i thought it would run right. when i ordered my swap from osake they sent me the wrong ecu and while i had to send that one back and was waiting for my p30 i ran the p28 just to drive it. not like i planned on getting a whole lot of power out of it.
b16nonoy
Feb 19, 2007 01:10 AM
CaptivaBlue
Apr 9, 2005 03:54 PM
