bleeding the brake
Old Jun 6, 2007 | 01:10 PM
xaznxdrgnxboix's Avatar
Default bleeding the brake
how do i bleed the brake fluid and how do i know all the brake fluid is out
Old Jun 6, 2007 | 01:17 PM
IIXtremeHansen's Avatar
Default Re: bleeding the brake (xaznxdrgnxboix)
simple. just start with the rear passenger, find the bleed plug loosen it, put maybe a clear tube or something onto the bleed hole so you can see if the air bubbles are gone. okay have someone pump the brake lets say 3 times then hold. tighten the screw let em pump 3 times and hold and loosen it and it should squirt out. make sure theres no air bubbles, has to squirt pure fluid through the tube and make sure the brake resevoir is filled with your brake fluid at all times. repeat through all brakes starting with rear passenger ,front driver, rear driver, and front passenger.
you may pump the system as many times you like if you dont feel that all teh air bubbles are gone.
dank24
11
Apr 2, 2007 09:26 PM
StolenTeg
Sep 5, 2006 05:05 PM
RTW DC2R
May 18, 2005 09:23 AM
byronl
23
Apr 20, 2005 03:18 PM
B18Redline
Jun 23, 2002 09:48 AM
