building poormans type r: should i change the fuel pump..?
Old Jun 6, 2007 | 08:36 AM
poormans_typer69's Avatar
Default building poormans type r: should i change the fuel pump..?
im building a poormans type r and its almost done... all i need is the small **** like fuel pump, water pump, injectors, fuel rail, and oil pan... I just want to know what they recomend me to get for this stuff...for ex: what kind of puel pump or injectors..well let me know..thanks
Old Jun 6, 2007 | 08:53 AM
ef_hatchback's Avatar
Default Re: building poormans type r: should i change the fuel pump..? (poormans_typer69)
well first, what kinda of car are you putting the swap into????
Old Jun 6, 2007 | 09:08 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: building poormans type r: should i change the fuel pump..? (ef_hatchback)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef_hatchback &raquo;</TD></TR><TR><TD CLASS="quote">well first, what kinda of car are you putting the swap into???? </TD></TR></TABLE>
Thats not really the factor.
Better question is, will it be N/A or turbo? Are you putting in really agggresive cams? Pretty much need to know the entire build. But you might as well just get a new Walbro. Its cheap and better safe than sorry
Old Jun 6, 2007 | 09:34 AM
what kind of car are you putting this swap into???
Old Jun 6, 2007 | 09:46 AM
crackerjacker006's Avatar
Why don't you give the guy a little more than a half hour to respond before asking the same question?
Old Jun 6, 2007 | 07:51 PM
well to anwser all the questions
this buil motor is going to be all motor NOT TURBO...
its going on a 94 civic hb..
pretty much what im putting into the whole things is
1.high comp. pistons (type r)
2.stage 2 camshafts
3.rebuilt block
4.rebuild head 3 angle valve job..ect.
5.dc sport headers
6.skunk 2 throttle body
7.skunk 2 intake magnifold
8.hondata s100 ecu
9.cometic head gasket kit
and im not sure what for
1.fuel injectors
2.feul pump
3.water pump
4.small **** you kno....
Old Jun 6, 2007 | 07:55 PM
b20beast978's Avatar
for a fuel pump a walbro 255 should do just fine...as for injectors some rc 310's should do the job
Old Jun 6, 2007 | 09:03 PM
cute little bastard
I have a similar setup and im using a 190lph pump and RC 310s.
motrayEG6
Jul 7, 2008 12:01 PM
SiR99
Aug 25, 2006 08:42 AM
pro547
Jul 7, 2005 07:48 PM
mrDFWmechanic
Jun 16, 2005 07:05 PM
dvp95
May 17, 2002 11:24 AM
