anyone use N20 on b18c5????
damn, all you all motor ****'s.....Nitrous is just a cheaper form of forced induction..I used to have it on my motor, I sprayed 100 shot direct port for a long long time....but gradually it wears pretty bad on your motor.
I would suggest just going a 50 shot wet, for that extra hp. Nitrous in large quantities don't get along with our higher compression. Below is a list of what you should get.
NOS single fogger wet kit
Nitrous pressure gauge
DYNO TUNING
1 step colder spark plugs
Retard your ignition to 14-15 degrees
and you should be just about set
DYNO TUNING
DYNO TUNING
DYNO TUNING
im spraying 80 wet on mine and works great . . ..
pin head ? 14-15 degrees? it should only be 2 degrees per 50 hp as a general rule of thumb.
mines only retarded 2degrees
well, stock is 16 degrees so I said 14-15, so that's 1-2 degrees...and the rule of thumb is usually 2 degrees per 50 shot ESPECIALLY with high compression....better safe than sorry, what are you gonna lose 1hp from 1 extra degree of retarding
i have all stock internals. i have had my nitrous on my car for about 17000 miles or so , but dont use it often .
my bad, i didnt know stock was 16 degrees. oops.
what do you guys advance the timing to for all motor power?
i heard 17-18 degrees?
because heres what i want to do , i have the dig 6 with the auto retard.
and i want to advance the timing all motor to get me a little bit more power all motor and then retard back to stock - 2 degrees when nitrous hit.
i heard 17-18 is where people are advancing it to . ?
crxrider07
May 12, 2008 01:19 PM
